Results 1 to 2 of 2
Thread: tankless water heater preasure problems
    DIY Junior Member Terryl18's Avatar
    Jan 2014
    Montana
    Default tankless water heater preasure problems
    i have an older double wide mobile home that i turned into a quad wide. the water comes out of the ground at the front of the trailer and the inlet to the house waqs 30 feet to the back and then the old hot water heater was 10 feet from the front so the3 old electric water heater went out and i had already purchased a new propane tankless water heater. when i started the instalation i moved the inlet to the front by where the water comes out of the ground so i only have 10 feet of water line that has to be insulated and where the main line comes in i have a t one side goes to the cold water for the house the other side goes directly to the water heater less than 10 feet goes through the water heater and back to feed the hot water for the house. everything works right accept the main shower wich is right next to the t , when you turn the hot water in the shower on it gets hot like it should but as soon as you turn the cold water in the shower on the water heater shuts off having trouble figuring it out. the main line from the ground is 1 inch in the house it t's off to 3/4in to the cold side and 3/4in to feed the hot side but the inlet and outlet on the tankless waterheater are 1/2in what do i need to change
    DIY Senior Member houptee's Avatar
    Aug 2008
    Monmouth County, NJ
    Are you saying the water heater inlet and outlet threaded fittings are designed for 1/2" pipe?
    I never saw a tankless that had 1/2" connections they usually always have 3/4" fittings.
    What brand and model is this water heater?
    What are the max and min flow specs etc?
  1. Bosch miniMAXX tankless instant hot water tank PROBLEMS!!
    By jmatsson in forum Tankless Water Heater Forum
    Last Post: 05-26-2012, 06:07 AM
  2. Delta Monitor Shower Valves and Takagi tankless heater problems
    By hptulsa in forum Shower & bathtub Forum & Blog
    Last Post: 10-27-2011, 11:56 AM
  3. Tankless Water Heater Problems
    By BlackDogKurt in forum Tankless Water Heater Forum
    Last Post: 09-05-2009, 03:59 PM
  4. Tankless water heater problems
    By srshaw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-04-2005, 05:15 PM
  5. Tankless hot water problems
    By casman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2004, 03:38 PM
