Results 1 to 5 of 5
Thread: Dishwasher/disposal wiring
    DIY Member JMingrone's Avatar
    Aug 2006
    Default Dishwasher/disposal wiring
    Do a disposal and DW HAVE to be on separate circuits? I have 2 circuits allocated for them, but one has plenty of capacity to run both. Can I simplify and run both off the one?
    Also, Can the NM cable just come thru a hole in the sheetrock into the area where the sinkbase will be and after the sinkbase is installed, put a JB inside?
    -Jay
    Depends...if the installation instructions call for separate circuits, you should use separate circuits. Disposers are available in at least up to 1Hp versions, which along with a DW that was heating the water, might overload the circuit. So, to preserve long-term potential changes and options, an extra circuit won't hurt.
    In some cases, if not MANY, since the disposer, (NOT "Disposal"), switch is combined with other switchs or outlets above the countertop level, it is wired into that circuit and the dishwasher is separate, even though the disposer and dishwasher share the same duplex outlet.
    Aug 2006
    Went ahead and ran both wires. Easy enough to do.
    Thanks guys,
    Jay
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    I would run a 14/3 cable, feed it from a 2 pole 15 ampere breaker, and cut the tab between the upper/lower receptacle on the hot side.
  1. Dishwasher and disposal same box
    By Steven Palmisano in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 05:36 PM
  2. Why should dishwasher drain go to disposal inlet?
    By dayster in forum Plumbing Forum Discussion & Blog
    Last Post: 06-20-2007, 08:14 PM
  3. Dishwasher with no Garbage Disposal
    By micalk in forum Plumbing Forum Discussion & Blog
    Last Post: 04-20-2007, 01:51 PM
  4. Garbage Disposal and Dishwasher problem
    By cbalding in forum Plumbing Forum Discussion & Blog
    Last Post: 05-26-2006, 10:25 AM
  5. Dishwasher Drain to Disposal Req'd?
    By whizmo in forum Plumbing Forum Discussion & Blog
    Last Post: 08-11-2005, 11:39 AM
