Results 1 to 5 of 5
Thread: Pressure Testing & Cleanouts
    DIY Junior Member PeteSC's Avatar
    Aug 2012
    South Carolina
    Default Pressure Testing & Cleanouts
    I pressure tested my DWV system yesterday for leaks using a test plug and filling the drain lines with water to flood level of the highest fixture. There were a few drips from two cleanouts in the system - would Teflon tape around the cleanout plug get rid of that? Is it even something to bother with?
    Thanks.
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    A retired plumber told me to use wax from a cheap wax gasket. Not only does it seal, but it screws in and out rather nicely.
    Aug 2012
    South Carolina
    Ooohhh.....I like that idea. Thanks!
    They are not under pressure, unless the drain is clogged, so you don't really have to worry about them. Testing is usually done to 10' above the floor, not the flood line of the fixtures.
    Aug 2012
    South Carolina
    Thanks. I've understood that a little drip from the cleanout wasn't anything to fret over but in the end it really comes down to what my inspector wants to see. Same for the pressure test - inspector instructed me to test it to the flood level of the highest fixture, so that's what was done.
  1. pressure testing well casing
    By cabincrazy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2011, 06:21 PM
  2. Pressure Testing Gas Line
    By cloves in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2010, 08:33 PM
  3. Pressure testing DWV
    By jar546 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2008, 04:04 PM
  4. Venting and Pressure Testing
    By maxprophet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-12-2008, 04:32 PM
  5. What pressure for air testing copper?
    By seaneys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-12-2008, 08:24 PM
