Results 1 to 6 of 6
Thread: Recommendations for the average intelligence tile setting homeowner: Shower edition
Hybrid View
    SomethingWittyHere dented's Avatar
    Nov 2012
    Utah, United States
    Default Recommendations for the average intelligence tile setting homeowner: Shower edition
    My wife convinced me we should replace the claustrophobic troubled shower in our house. We bought this house this summer, and knew right away the shower was a problem because we could see the mold from an adjacent room, where the drywall was cut out to illustrate what a great deal the place was. For someone with deep pockets. Heh!
    Right, so with the advent of the internet, so many options for the DIY seem, well, almost attainable. But which ones really are?
    I have tiled before, with success. I have even plumbed before with varying degrees of success. I didn't have to call in a pro, and everything worked as it should, even passed inspections.
    With that in mind, we cautiously decided we might be able to do this ourselves. And that's where we are now, having sawzalled out some stuff, and ready to really make the hard choices.
    First of all, I was sold on a pre-made pan, but the dimensions don't work quite right. It leaves an odd space adjacent to a toilet, and beside the shower in a corner if we use the largest we could find. Too deep for a cabinet, and awkward to access. We think we might be able to tackle a DIY shower pan. Or can we?
    It's not a lot of complicated dimensions, and there isn't much for walls, just a few. With no considerations for ADA, it should be pretty straightforward. She wants glass walls, but not all the way to the ceiling. She wants a linear drain with a single slope floor, if possible. She has picked out some huge tiles that were special order, and will be here in a few weeks, looming, reminding us that we haven't finished the walls and floor yet. Or even made a cohesive plan.
    And that's what I need help with.
    How do I decide what system to use? Kerdi, Webi, sheets of rubbery stuff, etc? It should be simple for the simple minded, compatible with the linear drain she wants, and not cost as much as a motorcycle. Because that's what she really wanted but is getting a shower instead.
    Is there a book, youtube videos anyone would recommend to watch? Not about the motorcycle, but the mudding of the shower.
    Jul 2009
    North Vancouver, BC
    Default Recommendation for shower drains
    Quote Originally Posted by dented View Post
    Hold on a second here. First off what type of tile did your wife pick? Does it have enough grip to be used in a shower?
    What type of linear drain are you looking at? Some are primary shower drains and some are not. The ones that are not primary drains work with a primary drain like a three piece clamping drain.
    If you are planning a pre-made pre-slope your options in linear drains drops to three choices - Wedi, Kerdi and Proline.
    BEtween these three Wedi and Proline offer up the most selection in setting material.
    Between those two Wedi's pan is more of a solid piece and Proline's is more of a honey comb you infill.
    Can you get access to Laticrete, Mapei, Ardex or Custom Setting materials?
    IS cleaning a concern with this drain?
    Do you need a hair strainer?
    Do you want it to light up?
    All questions that need answering to pick the best linear drain for you.
    One of my favourite drains is made by Proline but it is one of the hardest to install. The Kerdi drain is very similar to Proline's but the selection in thin sets is to limiting unless you have access to Ardex setting materials. Noble Companies linear drain works well and is easy to install I just don't like the screws that fix the strainer down.
    One of the best options out there is the drains from ACO - they are either a primary or non-primary linear drain. The Flanged version is a primary shower drain but I hate that one and would not recommend it. The Plain edged ACO drain however is one of the best drains out there.
    Made in Germany
    Electropolished.
    LED's availble .
    Hair Strainers available.
    Easy to clean.
    Take a peak at this Ideabook of mine of Houzz for selecting a drain.
    The linear drain top left is a Proline from Quick Drain USA.
    The two to the left are from Schluter Systems. The tile insert drain from Schluter was reworked last year and this second version is very good. I'm not a fan yet of their trimmed stainless versions since the trim and grill are so tight.
    http://www.houzz.com/ideabooks/36507...or-Your-Shower
    JW
    An advantage of using a linear drain is a single plane that is easier to tile...BUT, big tile CAN be quite slippery. This is one reason why most often, smaller tile are used since there are more grout lines that can add grip. Some big tile aren't like an ice skating rink when wet, some are quite dangerous - alright for a wall, but lousy for a wet floor.
    Several of the 'systems' houses, Wedi, Schluter, and likely most others, have some videos on their websites along with installation handbooks describing how to install. There's a Tile Council of North America (TCNA) that has a handbook that describes all of the tested and approved methods (that work reliably anyway) of how to do most anything with tile, including showers. They do charge for the handbook, and you can download it in toto, or in parts.
    A shower, properly constructed, with an approved method should last a very long time with no problems. Skip a step, or try to 'wing it' on your own, and there's no guarantee it will work.
    Nov 2012
    Utah, United States
    Interceramic Linen, Smoke color. It has some texture, not smooth.
    Unsure, probably best to settle on the rest first? Looking for advice.
    Unfortunately, I am not following you. If you mean using a pre made pan, I am afraid to say that it won't be possible with the dimensions she wants. I was against a huge shower, but I am not sure what else we can do with all that room otherwise. No doubt a sixty inch shower is fine, and a pre made pan would be really easy and much much faster. I am still hoping there is a way, but I haven't found it yet.
    I am just outside SLC, so unless I have to be a contractor to get them, I can probably buy them somewhere here.
    Not sure why it would be, we don't live in a museum, but we do clean the shower somewhat regularly.
    I live with two girls, so it's not a bad idea. Do you think I need one?
    Is this a joke? If there are drains that light up, I am pretty sure I wouldn't want one. Heh!
    Jul 2009
    North Vancouver, BC
    Default Recommendations for the LED Shower lights - ACO
    Make sure the tile is slip resistant enough before installing them.
    You should decide on a shower build and waterproofing approach first - this will help you pick a drain.
    Just build your own custom shower pan. Not that hard to do. Are you planning on a curbb or non-curbed shower. Barrier free showers are much harder and best left to the pros.
    Go find out. You will want to keep your setting materials and grout in one family.
    Some of the linear drains are harder to clean than others. ACO my favourite in this department.
    Most drain companies do not have a hair strainer. Once again ACO has a slick one that you can order.
    I rarely kid about shower drains. Do you like Reggie Music? Here is a little drain lighting and Reggie mixed together.
    One of my projects here in West Vancouver. The lights are from ACO and designed only for their drain. I'm working on a side lit drain from Proline but this is outside of their specifications and for a buddy's place. I'll show some pictures in a few weeks once we get it figured out.
    JW
    Jul 2009
    North Vancouver, BC
    Default Shower drain recommendations for large shower with linear drain
    I'm thinking the linear drain from ACO would be a good fit for you. NOT the flanged linear drain but the plain edge one. The Plain edge drain works with a three piece clamping drain and any waterproofing system out there designed to tie into this type of clamping drain.
    There is a good play by play on this Youtube video.
  1. Taking a Tile Course Online - Learning the trade of tile setting via the Internet
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 09-05-2012, 05:52 AM
  2. Culligan Medalist WS setting recommendations?
    By HiccaBurp in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-16-2011, 09:22 PM
  3. Setting mosaic floor tile
    By khayes in forum Remodel Forum & Blog
    Last Post: 04-21-2009, 07:41 AM
  4. Tile setting - use of premix grout to level surface?
    By AcidWater in forum Remodel Forum & Blog
    Last Post: 03-20-2009, 08:55 PM
  5. Setting toilet to tile/concrete slab advice
    By joey024 in forum Toilet Forum discussions
    Last Post: 11-01-2008, 04:33 PM
