Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Am I supposed to use a metal washer inside the tank or not?
    DIY Member LBrandt's Avatar
    Feb 2007
    Louisiana
    Default Am I supposed to use a metal washer inside the tank or not?
    Hello,
    I'm getting ready to replace the washers and bolts connecting my American Standard Cadet 3 tank to the bowl. I just bought a tank bolt kit at Home Depot, and the guy there said to use the metal washers on both the inside and outside of the tank. In other words, he said that the metal washers were supposed to go between the bolt head and the rubber/cloth washer inside the tank and between the nut and the rubber/cloth washer underneath the tank.
    However, in reading another post on this forum, someone (I've since lost the reference) said that the metal washer should not go between the bolt head and the rubber/cloth washer.
    And there is a second part of my question. Where does the bottom rubber/cloth washer actually go? Does it go underneath the tank between the tank and the bowl, or does it go under the bowl?
    Louis
    Apr 2012
    New York, NY
    The metal washer does NOT go inside the tank.
    If you have a set where for each bolt there is one rubber washer, one metal washer and a nut, then the order is bolt head in tank, rubber washer under bolt head in tank, then the metal washer and nut go under the bowl.
    See diagram 3B HERE
    If you have a set where for each bolt there are two rubber washers, two metal washers and two nuts, then the order is: Bolt head and rubber washer in tank, metal washer and nut on outside of tank, then, under the bowl, rubber washer, metal washer, nut. See Korky diagram 6A HERE, for example. Or Fluidmaster instructions: HERE
    Toto gives you two metal washers and only one rubber washer; they don't have you put a rubber washer under the bowl. See illustration 4 on page 5 HEREfor how to do the inside of the tank, and the text of the second paragraph of instruction 5 as to how to do the under-the-bowl.
    As to your second question, the rubber washer (assuming you have two per bolt) goes under the bowl. See diagram 6A above.
    Lots of handymen (and, apparently, aprons) think that you put that metal washer under the bolt head. Do that, and you are reducing the seal between the bolt head and the rubber washer, with which the bolt head should be making a watertight seal, and reducing the ability of the bolt head to seat the rubber washer against the tank. Hence, you are increasing the chance of a leak.
    Bottom line, you have metal against metal underwater in a place you are trying to have a watertight seal. On the face of it, that's obviously wrong.
    There is no rational reason to put the metal washer inside the bowl. I think the myth arose because dummies bought bolt sets without knowing how to do the installation, and just guessed at where stuff was supposed to go; then they showed others how to do it the same, wrong, way, and that's how many people have learned to do it. But it's irrational and totally-wrong.
    Now, under the bowl, it's a different story. There, you have a nut, and you are using the nut to compress the metal washer against the rubber washer against the bowl.
    By the way, the consensus on the forum is that a good-quality set that has two nuts, two metal washers, and two rubber washers per bolt gives an installation that is the least likely to leak. The idea is to make the seal between the bolt head and tank first, using the nut and metal washer. Now you have a bolt coming nice and straight out of the tank, held in place, and a nice seal between the bolt head and tank, before you even start reattaching the tank. That straight bolt, held in place, is going to make it easier to properly-reattach the tank. Put another way, the attachment hardware has two missions: (1) make a waterproof seal and (2) hold the tank in place. The way we prefer to do it, you have a set of washers and nuts for each mission and you do each mission separately: i.e. make the seal and then reattach the tank. It's possible to use one metal washer and one nut to apply the tension necessary both to make the seal and also to secure the tank on the bowl, but your long-term success rate is likely to be enhanced by doing each job separately.
    Of course you still have to tighten down the tank slowly and carefully, keeping it vertical and alternating side-to-side (i.e. tighten a little on the one side, then a little on the other, so it stays basically straight as you are pulling it down to meet the bowl). Stop the moment you have any china contact against china, because one more turn and you will likely crack it. When you stop tightening, examine whether the points of contact are correct. If not, loosen, straighten and try tightening again. You should have no wobble of movement in the tank, but only a whiff of contact between china pieces.
    If you want a good giggle, here's a thread on this from Dimwit City: BAD ADVICE Another good reason to hire a plumber not a handyman. (Or do it yourself with the excellent, professional advice that real plumbers Terry, HJ, Jimbo and others give here.)
    Feb 2007
    Louisiana
    WJCandee,
    Thanks for your reply. I understand what you're saying, and now I completely agree with you about not using a metal washer inside the tank. But I still have a question. I don't understand the function of the rubber washer under the bowl. If, for some reason, water should penetrate the rubber washer inside the tank, that water would be able to drop to the floor since there is a space between the bottom of the tank and the top of the bowl. The rubber washer under the bowl wouldn't be able to stop that water, because the water could just run sideways to the edge of the top of the bowl and drop to the floor.
    In any case, why not use a third rubber washer directly under the bottom of the tank with another nut holding it tight to the underside of the tank. Then, you'd have a rubber washer on both sides of the tank and still have a third rubber washer underneath the bowl.
    As a matter of fact, I just went back to Home Depot and bought another tank and bolt kit, and the instructions on the outside of the package shows a rubber washer under the bottom of the tank. Like your advice, it has no metal washer inside the tank, but it does have a rubber washer on either side of the tank bottom.
    Louis
    It goes:
    bolt head
    rubber washer
    bottom of tank
    And then two choices
    If only one washer and nut, those go under the bowl mounting lip.
    If they give you a second rubber washer, that can go between the bowl mounting lip and the washer and nut
    If they give you two washers and two nuts, one set goes under the tank, and the second set under the bowl mounting lip.
    The only time a stainless steel washer is used "inside" a tank, is with the TOTO Aquia, and that is considered strange.
    Feb 2007
    Louisiana
    Thanks Terry,
    Well, it really wasn't a case of what they gave me. I bought a kit that had four rubber washers, four metal washers and four nuts. Then I bought a second kit, so that I'd have enough to put a set under the tank.
    The only other question that I have is this: Should I use a metal washer under the tank (between the rubber washer under the tank and the nut)?
    Louis
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    No rubber washer should have an ordinary nut pressing against it. A skirted nut can be used alone as it acts like a washer. My stock AS Cadet 3 had a skirted nut for use under the bowl.
    Bill
    Just a DIY'r
    Apr 2012
    New York, NY
    Quote Originally Posted by LBrandt View Post
    You need the bolt head and rubber washer in the tank; you need a metal washer and a nut under (outside) the tank.
    If you are going to put a rubber washer on the outside of the tank, it better have a metal washer between the nut and it. But I wouldn't use the rubber washer, because as it degrades over time, it potentially will cause the seal between the bolt head and washer on the other side of the tank to become less tight.
    Feb 2007
    Louisiana
    Quote Originally Posted by wptski View Post
    I didn't say that I was going to put an ordinary nut against the rubber washer. My question was whether I should have a metal washer against the rubber washer underneath the tank.
    Feb 2007
    Louisiana
    Quote Originally Posted by wjcandee View Post
    WJCandee,
    I don't understand why you are saying that if the rubber washer under the tank degrades, that it could affect the rubber washer inside the tank. The two rubber washers don't touch each other. They would be on either side of a thickness of porcelain. How could one rubber washer affect the other one? If they were touching each other, then I might agree with you, but they won't be touching.
    Louis
    quote; I bought a kit that had four rubber washers, four metal washers and four nuts. Then I bought a second kit, so that I'd have enough to put a set under the tank
    According to my calculations, if you use one nut on each bolt under the tank and one nut on each bolt under the bowl, you only need FOUR nuts, so why buy the second set? That "bad advice" site is the "blind leading the blind" because almost NONE of the answers were completely correct. The rubber gasket under the tank is a "user preference" it has little benefit and no detriment. If you have them, use them, but do not lose any sleep over it if they did not furnish them. Rubber washers between the metal one and the bottom of the bowl is a better choice, however.
    Feb 2007
    Louisiana
    hj, thanks for your reply. When I said that I bought a second kit, I didn't mean that I bought a second kit with bolts and metal washers. I simply bought a second kit which contained only 4 rubber washers and nothing else. I didn't elaborate on the second kit, because I was simply trying to say that I bought more rubber washers. I am sorry if my statement about the second kit was misleading.
    Louis
    Feb 2007
    Louisiana
    I now want to apologize to all of you, especially WJCandee. I now see why I wouldn't want a rubber washer directly under the tank. Even though the two rubber washers wouldn't be touching each other, I now see that if the rubber washer under the tank were to wear out, the metal washer and nut below it would no long be exerting an upward force, and the washer inside the tank would no longer be held tight against the porcelain.
    Again, I'm a novice when it comes to most plumbing jobs, and that's why I knew that I would get the correct answers on this forum.
    Please forgive my many questions and my continued hard-headiness in not understanding what you all were telllng me.
    Best to all,
    Louis
    Oct 2012
    Warren, MI
    I should have been more clear. You need a washer which has a larger surface close to or equal to "any" rubber washer to distribute the force of the nut. A nut used alone might twist/deform/cut the rubber washer and a metal washer is a buffer between the two.
    Bill
    Just a DIY'r
    Apr 2012
    New York, NY
    No apologies necessary, Louis.
    It's fun to be able to help.
    Feb 2007
    Louisiana
    Thanks again to all of you.
    Best regards,
    Louis
  1. Toto Vespin tank supposed to be loose?
    By nuke in forum Toilet Forum discussions
    Last Post: 12-23-2012, 04:35 PM
  2. When you have a beveled metal washer intergrated into a faucet supply hose.....
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2012, 01:46 PM
  3. PVC Inside Metal Pipe
    By jandrew in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2008, 08:03 PM
  4. Leak inside the tank
    By jsanfilippo in forum Toilet Forum discussions
    Last Post: 03-27-2008, 06:01 PM
  5. cleaning the inside of a hot water tank
    By Alexdc99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2005, 10:26 AM
