Results 1 to 3 of 3
Thread: Bottom of shower drain broke out?
    DIY Junior Member williet57's Avatar
    Nov 2012
    columbus ohio
    Default Bottom of shower drain broke out?
    We have a rental mobile home, that in the shower stall,the drain has broken out and is just supported by the trap and drain line.
    I know the solution is replacing the pan but try and see if there is an easy solution. The hole in the shower drain pan is 4-5/8" dia. If they make a flat top 5" drain it would fix it.
    Any solutions on this?
    Sep 2009
    Seattle. WA
    Sell the m/h and let the new owners deal with it.
    Jan 2008
    If it is a fiberglass pan it can be repaired, but it will cost more than a new replacement.
  1. Broke the shower pipe changing the head
    By ramzmusic in forum Shower & bathtub Forum & Blog
    Last Post: 12-17-2008, 07:56 PM
  2. Drain lever broke
    By jamz39 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2008, 08:47 AM
  3. Cast Iron Drain to Sewer 90 broke... Now what?
    By LT_DIY in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-27-2008, 07:49 PM
  4. Shower arm broke off..nut stripped?
    By a12548 in forum Shower & bathtub Forum & Blog
    Last Post: 06-02-2008, 07:53 PM
  5. Need to replace shower drain, broke cross in drain...
    By BustedKnuckles in forum Shower & bathtub Forum & Blog
    Last Post: 07-25-2007, 08:22 AM
