Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Relocating kitchen stub out
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Default Relocating kitchen stub out
    Long story short, we re arranged kitchen cabs, and bought a deep undermount sink. My stub out ended up here:Name:  kitchen counter sink 008 (Medium).jpg
    Name:  kitchen counter sink 007 (Medium).jpg
    So I cut out the 2x1 1/2" SAN T , lowered another one 3", and ran it Horizontally 8" or so, and installed a 1 1/2" sweep to stub it out in a better place between the bowls.
    Name:  kitchen counter sink 012 (Medium).jpg
    So my question is, is this really kosher? Or do I need to move the whole island set up over?
    It is the way we do it at least 50% of the time.
    Sep 2012
    Anaheim, Ca.
    Thank you HJ. Now for my next question.
    Is there a way to legally install like a combi wye on the stub out to use a trap for each bowl? I don't think I care for the directional center t deal.
    Sep 2012
    Anaheim, Ca.
    I think I figured it out. If I add a san t above this one, and stack another one on top to the other side, it's low enough to hit the basket. The disposal was the issue being lower. Thanks again. J
    FWIW, that flexible rubber coupling is not allowed inside the house - it should be a reinforced no-hub fitting. Thinner rubber, full metal jacket to keep the pipes aligned.
    Sep 2012
    Anaheim, Ca.
    If I had known that, I would have used the appropriate fitting.. Since I am done, and it's just an overkilled 2" island vent, that should never see a snake, I am going to let this one go. The pipes are only 1/8" apart, and I used it with dishwashing soap to make a slip coupling.
    Sep 2012
    Anaheim, Ca.
    Finished product. I like the idea of seperate p-traps for the disposal and sink.Name:  kitchen counter sink 014 (Medium).jpg
Size:  62.2 KBName:  kitchen counter sink 015 (Medium).jpg
Size:  62.7 KBName:  kitchen counter sink 016 (Medium).jpg
    Jan 2008
    That would fail inspection in some areas as you now have a wet vent on the lower trap.
    Sep 2012
    Anaheim, Ca.
    With what you see here, is there a way to re-arrange the fittings and vents in this space to comply with UPC code?
    UPC would be happy with a fixture cross, or to stub out once and use a disposer kit with one p-trap.
    A fixture cross puts the trap arms at the same level as the vent, which makes it correct.
    Or stub once, and connect under the sink.
    There are a lot of things that hj says he does in Arizona that I can't do with inspections.
    Sep 2012
    Anaheim, Ca.
    Terry, could I replace the lower 90* sweep with an 1 1/2" wye, making both stub outs the same heigth, and abandon the top stub?
    I understand the wet vent thing, but the only danger would be draining both bowls at the same time.
    I could use the top as a C.O., and use the single stub. But I hate the idea of those divided t's.
    quote; you now have a wet vent on the lower trap.
    Isn't that the idea and purpose of a "wet vent". I would not have done THIS installation that way, but have "stacked" tees for multiple fixtures many, many times, (especially if they had different drain height requirements which a back to back fitting would not accomodate), and they were ALL "inspected" and approved.
    Sep 2012
    Anaheim, Ca.
    So HJ, the ultimate question. BTW, I already passed inspection, so I seek practicallity. Do you think it is an issue?
    What would you have done?
    Sep 2012
    Anaheim, Ca.
Size:  62.2 KBOkay. I have an idea, so here goes. If I tapped off the vent up high, and ran a 2" across the top, down, and t'd into the bottom trap arm reventing it on the left, would that be legal?
    I just hate the idea of crawling under the house and shifting the whole deal over. Thoughts?
    What you have is "legal". What you propose to do is "busy work". I have no aversion to the directional tee so I would have left it as it was originally. BUT, if I did "really want" separate openings for each sink, I would have centered the opening and then used a "double Y" with a cleanout in the center opening. You should understand that people pay me for my time, so I do not see any purpose in making the job more difficult just so I can charge more. In addition, no matter HOW it was done, I would not have used a 2" pipe for the horizontal portion.
  1. Relocating Kitchen Sink
    By Bart7 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-03-2010, 06:47 PM
  2. Standard DWV stub out height for kitchen sink
    By spresco in forum Plumbing Forum Discussion & Blog
    Last Post: 01-30-2009, 09:56 PM
  3. Relocating well pump
    By Fishguy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-03-2008, 09:41 AM
  4. relocating washer
    By knucklehead in forum Plumbing Forum Discussion & Blog
    Last Post: 02-09-2007, 01:19 PM
  5. relocating stove
    By zenrgie in forum Plumbing Forum Discussion & Blog
    Last Post: 08-19-2005, 08:40 AM
