Results 1 to 2 of 2
Thread: How to determine what kind can light
    Default How to determine what kind can light
    I'm getting ready to add another layer of insulation in the attic. I have 3 can lights that were probably installed in the past 10 years but there's no label indicating if I can insulate around them. I've looked up in the attic and removed the baffles to look for any information. Is there a way to determine this?
    There's a label somewhere on the can - it might be inside under the trim. If it's not IC rated, you must leave space around and above it. You can use a box around it if it leaves at least the minimum space, and put insulation on top of that, though. You need space to the sides and the top.
  1. Help to determine which is Vent
    By donfenyk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-24-2009, 09:15 AM
  2. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  3. pilot light wont stay light on furnace
    By possum in forum HVAC Heating & Cooling
    Last Post: 10-07-2008, 12:48 PM
  4. How to determine rough-in
    By jechow in forum Toilet Forum discussions
    Last Post: 06-09-2008, 06:49 AM
  5. How to determine what length faucet I need
    By bleon0 in forum Remodel Forum & Blog
    Last Post: 07-19-2005, 12:19 PM
