Results 1 to 9 of 9
Thread: New blogger. How to wire a fan with light?
    DIY Junior Member Molly d's Avatar
    Nov 2012
    Illinois
    Default New blogger. How to wire a fan with light?
    I replaced a ceiling fan and light with a new one. I have two switches on the wall one for the light, one for the fan. Fan works. Lights work pulling on the chain, but not on the wall switch. I put white to white, green to green, black to red, black to blue. I don't have the the instruction. Please help if you can.
    Jun 2007
    North Carolina
    With the light on by pulling the chain will the wall switch turn it off?
    Aparently you missed the wire from the light switch and connected the lights to a "hot" black wire. I do not know how you could have done that if you just removed one fan and replaced it with another one, but that is the only thing that makes sense, given your description. If both black wires were from switches, there is absolutely no way the lights could be on when both switches were "off".
    Nov 2012
    Illinois
    Unhappy
    Quote Originally Posted by jwelectric View Post
    No, it does not work turning it on or off.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Tough to say.
    You have been turning the power off each time you open the system up?
    Have you opened the switch box up and inspected how the switches are arranged?
    Do so with the power off, please.
    quote;Have you opened the switch box up and inspected how the switches are arranged?
    What difference would that make? If he did not open it when he replaced the fan then nothing in the switch box has changed, and any "miswiring" has to be in the fan's mounting box.He has to find a "switched" wire, which may or may not be black, at the fan and disconnect the light from a "hot" wire.
    Jan 2012
    Los Angeles, CA USA
    I'm curious to see what is in there. I would certainly open it up if I were walking in at the top of the thread.
    But if you have the solution please feel free to hand it over.
    quote; But if you have the solution please feel free to hand it over
    I have already posted the "solution" TWICE, but since I am not there I don't know how to tell him how to implement it without using a "Tic Tracer" to find the wire that is only energized when the switch is turned on.
    Jun 2007
    North Carolina
    Quote Originally Posted by Molly d View Post
    will either switch turn the light off. Does the light not work if the switch for the fan is off?
  1. 4 Wire Cooktop and Oven to 3 Wire Sub Panel
    By TJanak in forum Electrical Forum discussion & Blog
    Last Post: 12-29-2011, 05:45 PM
  2. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  3. 4 Wire Cable in a 3 Wire Connector Setup
    By chefwong in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2009, 03:17 PM
  4. Wire question on bathroom fan/light combo
    By gmaninca in forum Electrical Forum discussion & Blog
    Last Post: 05-17-2009, 01:20 PM
  5. pilot light wont stay light on furnace
    By possum in forum HVAC Heating & Cooling
    Last Post: 10-07-2008, 12:48 PM
