Results 1 to 15 of 15
Thread: No water in shower?
Hybrid View
    DIY Junior Member carzt's Avatar
    Nov 2012
    Philippines
    Default No water in shower?
    I'm renovating an existing house which I don't yet live in. The bathroom was just redone (including new pipes) by a professional plumber. There is quite good water pressure in the sink, light pressure in the rain shower, and just a very slight trickle in the shower and bathtub. The plumber says the pressure is too low, and suggests a water pressure tank. Note this is in the Philippines.
    I've included a diagram of the plumbing below.
    Is it likely that the lack of water in the shower/tub vs. the sink is just low pressure due to the additional elbows in the pipe going to the shower/tub (8 elbows) vs. to the sink (5 elbows)? How can I estimate the additional pressure required (and thus whether a pressure tank will help and what I should get)?
    Thanks for any advice,
    Chris
    Name:  Bathroom Plumbing Diagram.jpg
    With low pressure elbows have negligible effect on the delivered pressure. We would have to know more about your system, such as whether it is a gravity system using a tank on the roof, or where the water comes from. A "pressure tank" does not create pressure, so it will not help unless you have some way to pressurize it, such as a water pump.
    Nov 2012
    Philippines
    The water comes directly from the main water utility pipe. No water tank on the roof.
    If we get a pressure tank, it would of course be accompanied by a pump to create the pressure
    The size of the pipes and the actual pressure you have will determine how much water you can get there. If the pipe diameter is too small, or the pressure is low, you cannot provide enough volume to do what you want. Now, how many heads are you trying to run in the shower at once? That may be an issue with the valve chosen...it might just have too small internal passageways to provide the desired volume at a nice pressure.
    I dont know how easy it would be to find, but a pressure gauge is the only way to actually tell what your supply pressure is. In the USA, you can pick up a reasonable one for about $10US. As HJ said, the number of elbows probably isn't an issue, and if it is, its effect is small.
    They do make products that increase water pressure, typically and tank and pump combined to boost the pressure.
    A few fittings on the way to the valves isn't causing your problem. You may want to try flushing the lines though. Have you put a pressure gauge on the system to find out what your static pressure is?
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Maybe some kind of obstruction got into the mixer or diverter valves?
  1. Shower water do not flow when water is running in bathtub
    By Luwork in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2011, 09:53 AM
  2. water line issues between shower and hot water tank drain P-trap
    By ns in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2011, 10:55 AM
  3. Low shower pressure-hot water only-1 shower only
    By mindfrost82 in forum Shower & bathtub Forum & Blog
    Last Post: 04-30-2009, 02:40 PM
  4. Shower hot water issue - hot from tub faucet, lukewarm from shower head
    By mikea128 in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2006, 06:37 AM
  5. replaced 1964 shower/tub faucets,now shower water pressure down significantly
    By very ignorant homeowner.. in forum Shower & bathtub Forum & Blog
    Last Post: 05-28-2006, 04:30 PM
