Prime it where the gauge goes, and check to make sure the gauge is not bad. MSE's are real bad about not pumping if there is even a small amount of air in the system. Once you get it going screw the regulator to 60 psi (that's the pressure feeding the jet). You can pull the plug on the bottom out to help prime faster, it lets the air out.
