Results 1 to 3 of 3
Thread: Weak flush
    DIY Member coopns's Avatar
    Sep 2006
    Massachusetts
    Default Weak flush
    Pulled off the toilet, thought it was leaking, wasn't. (2 year old can't quite make it all the way).
    So I put on two wax rings (flange was below floor...add PVC ext. rings...both waxed together). One had a funnel. Felt a good squish when I put it down. We have noticed though the flush is weaker then before I took it off and have the two rings. The previous ring had a funnel but only one ring. Any thought's on what might be happening? Why the weaker flush? Same amount of water...Frustrated...
    If you get things offcenter, the plastic horn in the wax ring can get collapsed partially. Or, if the excess wax intrudes into the drain, that can narrow the drain and mess things up.
    The obvious answer, but maybe not the correct one, is that you did something wrong when you put the toilet into place, but the only way to tell for sure is to remove it and look. I am not a fan of spacer rings, but only because they are not always secured properly, which means they can be the cause of problems in the future.
  1. Weak flush
    By richrc1131 in forum Toilet Forum discussions
    Last Post: 11-24-2012, 03:51 PM
  2. Weak Flush problem
    By Brusker in forum Toilet Forum discussions
    Last Post: 11-01-2011, 02:31 AM
  3. Weak flush...something stuck?
    By coopns in forum Toilet Forum discussions
    Last Post: 02-17-2011, 09:50 PM
  4. Weak flush
    By gbh in forum Toilet Forum discussions
    Last Post: 12-19-2008, 04:11 PM
  5. weak flush
    By daves in forum Toilet Forum discussions
    Last Post: 10-06-2004, 05:52 AM
