Results 1 to 5 of 5
Thread: Please HELP! Under shower handle there is a metal handle that will not come off!!
    DIY Junior Member xxarmanxx's Avatar
    Nov 2012
    Richmond, VA
    Default Please HELP! Under shower handle there is a metal handle that will not come off!!
    No brand visible. I removed the single screw and plastic handle cover only to find a metal cover which will not come off. How do I get the metal cover off? I tried everything I could think of. feel free to email me at xxarmanxx@aol.com
    I turned it all the was to the left (fully open) and put some pressure ...nothing. Puller straight out...Nothing.
    So frustrating.
    With the thousands of valves produced over the years, no way without seeing what you have...post a picture of the valve and you have a chance of some useful help.
    Nov 2012
    Richmond, VA
Size:  46.5 KBName:  IMG_1112.jpg
Size:  34.5 KBName:  IMG_1113.jpg
Size:  38.9 KBName:  IMG_1114.jpg
    Here are pictures. Under the plastic covers where these metal covers which turn just like the plastic ones and go in and out as you turn them.
    Plumber jimbo's Avatar
    That is the handle adapter. Put the pin of a handle puller into the hole and hold the puller fingers under the edge. Soaking the whole thing in white vinegar for a while may help. It is just stuck
    The pin on a handle puller may not be long enough to let the adapter pull loose. Grab the top and bottom of the adapter with a large pair of Channelock pliers. The "jiggle" it up and down while pulling very hard. Do this for a few times, the grab the handle "sideways" and do the same thing to the left and right. Keep alternating between up and down, then left and right, and the adapter should come off it you are pulling hard enough. Tha looks like a typical American Standard faucet.
  1. going from two handle shower body to one handle-- using converter plate
    By dayexday in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2012, 06:47 AM
  2. Can't move metal nut on toilet handle.
    By Tarazed in forum Toilet Forum discussions
    Last Post: 01-15-2010, 11:35 AM
  3. Shower handle and trim for 22 year old pull-out handle
    By Steveindanville in forum Shower & bathtub Forum & Blog
    Last Post: 12-23-2009, 10:27 AM
  4. single-handle Aqualine shower handle
    By marchat in forum Shower & bathtub Forum & Blog
    Last Post: 12-29-2006, 02:18 PM
  5. two handle vs single handle tub/shower
    By PaulHG in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2006, 02:08 PM
