Results 1 to 5 of 5
Thread: Laundry stack - can pipe size be reduced?
    DIY Junior Member Michael Gerst's Avatar
    Nov 2012
    Missouri
    Default Laundry stack - can pipe size be reduced?
    I am finishing off our basement laundry, and currently there is a 3" stack coming up out of the floor. The trap is under the concrete. Is it acceptable to reduce the pipe size to 2" in order to hook up to a washing machine outlet box, or is there a outlet box with a 3" spigot or hub connection? I fall under IRC here - they still go by the 2006 edition.
    Jan 2008
    The standpipe with trap can be 2", and needs to be above the floor. This can connect to the 3" line going into the floor. The trap below the floor will need to be removed.
    Between the 3" stack and the p-trap, you will need a vent.
    Trap above the floor.
    Jan 2008
    I do recall another member posting here that the 3" standpipe with the trap in the floor is specifically permitted by a local Missouri code. I didn't believe it at the time but did find it in the MO code.
    DIY Junior Member mikeygstl's Avatar
    Apr 2012
    Saint Louis, MO
    I do know the 3" stand pipe is permitted, with a trap beneath the floor, as it was inspected and passed justa few months ago. The problem I am having is that I now need to find a way to connect this stand pipe to a 2" washing machine outlet box.
    I'll talk with the inspector this afternoon when I pull the permit and report back what I find.
  1. Plumb Washer & Laundry Sink Into Existing Stack
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2011, 04:00 AM
  2. laundry drain size?
    By rick.a in forum UPC Plumbing Code Questions
    Last Post: 01-21-2011, 07:22 AM
  3. basement laundry in old house - washer stack overflow!
    By CYBERJUNKIE2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2009, 12:26 PM
  4. Soil stack size
    By KLB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-29-2008, 10:17 AM
  5. What size stack for a washing machine?
    By cwolters in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2005, 04:56 PM
