I don't know how that one works, but on my variable speed air handler, there is no external control on the fan speed from the thermostat. There is an adjustment to specify the max CF/M for your system programmed into the air handler, but none in the thermostat which only has on and auto settings. On mine, the fan only runs at a very low setting in the on position unless heating or cooling is called for, then it adjusts based on the time the call is, ramping up to max if there's enough time, then back down to either off if in auto, or the lowest speed if in on.
