Results 1 to 10 of 10
Thread: 80 gallon galvanized water pressure tank
    DIY Junior Member tksattler's Avatar
    Nov 2012
    Minnetonka, MN
    Default 80 gallon galvanized water pressure tank
    I have an 80ish gallon galvanized water pressure tank that I no longer need. See photo. Does anyone know if this is worth anything? Should I just hope that someone will take it for free and get it out of my basement, or could I sell it? How much...? Any comments are appreciated!
    Jan 2008
    The scrap metal guys will haul it away for you. It's not worth much unless you are broke.
    DIY Junior Member 6t7gto's Avatar
    Jan 2010
    Bedford, Ohio
    My son just replaced his. It cost him $200.00 for the tank.
    Try craigslist. Someone may need it in a pinch.
    david
    There would be few people who would take a chance on installing it because it already has rust stains on it. You might find a scrap dealer who would pick it up and pay you for it, but most would charge you to take it away.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by 6t7gto View Post
    Try craigslist...
    Ja, folks like to browse CL just to get a good laugh.
    ...most would charge you to take it away.
    Ja like all the "free firewood" ads on CL. They have a standing dead hazard tree that would cost them thousands to have removed by pros, and they think that a pro with $5M insurance coverage will remove it for free just for the firewood! Always good for a laugh!
    Feb 2011
    NW Ontario, Canada
    Try 1-800-GOT-JUNK.
    Try putting in the trunk of your car and taking it to a junk yard. They WILL give you a couple of bucks for it, maybe enough to pay for the gas to take it there.
    Nov 2012
    Minnetonka, MN
    Thanks. Got Junk sounds like my best option. I may try free on CL first, though my hopes aren't high. The tank weighs a ton.
    Jan 2008
    If the tank is heavy, it is probably because there is a mass of sand or other sediment in the bottom of it. I have heard of people cutting them into sections with a sawzall to make it easier to get them out of basements.
    The new replacement tanks are paper-thin and only weigh a fraction of the old ones.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by tksattler View Post
    Probably you will get a response from the same crack heads that are stealing copper to sell to scrap metal dealers. They will probably ding your walls and gouge your floors trying to haul it out. At the same time they will case the joint so that they can come back for the copper that is worth so much more.
  1. Life expectancy of galvanized pressure tank?
    By DCS in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-15-2012, 06:24 PM
  2. Galvanized Pressure Tank Question
    By muddyriver in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-16-2011, 10:50 AM
  3. Pan for a water heater - regular 50 gallon tank
    By richard8 in forum Water Heater Forum, Tanks
    Last Post: 04-05-2010, 01:14 PM
  4. Ariston 2.5GL gallon electric tank water heater
    By Cali in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-27-2008, 07:27 AM
  5. Galvanized pressure tank 911
    By shyleeblue in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2006, 04:01 PM
