Results 1 to 4 of 4
Thread: Ultra filtration systems
    DIY Member ByteMe's Avatar
    Nov 2012
    Midland Texas
    Default Ultra filtration systems
    http://goodwatercompany.com/Products...ter/index.html
    Doesn't need to be those exact systems but systems that use the same process.
    Anyone have any experience with these? Good/Bad ? How long will the filter last? Typical waste water from the cleaning cycle?
    Jan 2012
    California
    Very niche market, more marketing than functional. Very limited application. Traditional methods are typically a lot less expensive, last longer, and simpler. UF is ideal for removing cysts, viruses and bacteria but other methods are also very effective and less expensive. http://www.csmfilter.com/upload/csm/...2515114753.pdf Check out this link for details about the specifications for a common UF membrane.
    Nov 2012
    Midland Texas
    Seems to me, it might be cost effective as a stage before RO in commercial/industrial application. Thanks for that link.
    Jan 2012
    California
    It is very commonly used for pre ro treatment, primarily in waste water application, and even desal. I would guess that 99% of applications, it has no use. Advances in traditional membranes and higher quality low fouling membranes have eliminated a lot of the UF from a lot of the builders.
  1. New Whole house filtration
    By 4bsydow in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-03-2012, 12:25 PM
  2. New Whole house filtration
    By 4bsydow in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-28-2012, 12:24 PM
  3. water filtration
    By tooks7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-10-2011, 12:25 PM
  4. filtration system
    By lati_cz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-13-2011, 09:02 AM
  5. Water filtration
    By Nebbiolo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2010, 02:56 PM
