Results 1 to 11 of 11
Thread: what is the best shower pan installation
Hybrid View
    In the Trades Rob K's Avatar
    Nov 2012
    Seattle
    Default what is the best shower pan installation
    I a general contractor, and I am building a new shower (in my own place). I was hoping that you could give me your opinion for what you would consider the best method or product to build a shower pan with a curb. I have not chosen my products yet so I can build it any way.
    I hate to show my age but the last time I built one I lined it with lead and mortar.
    My tile setter recommended using a Wedi shower pan but I'm not convinced. On the walls the Wedi seems flimsy. I was considering using Denshield. For shower surrounds I usually use cement board with red guard
    There are numerous methods, and done properly, they all can work quite well. Some can go together faster than others, with Wedi being one of the faster ones - you can have a bare studwall and subfloor, once the plumbing is set, potentially have it tiled in one day. Hard to do that on other systems where you want a full, tiled shower.
    My personal preference is to use a surface waterproofing method rather than a conventional one. Redgard does work, but (this is a personal thing), I find it hard to ensure I get a full coverage at the required thickness without having areas either too thick, or too thin, or a pinhole here and there. Then, you have surface membranes, and there are at least several available to you in the states. I've used and been trained on Kerdi, which I like. You have a choice of either using a preformed pan, or building one with deckmud (cheaper, and easier to ensure it's level and the drain lines up properly), then cover it with the membrane. It is required to use their special drain, but I've found it to be very handy as you can easily adjust the exact placement after the main drain is installed for the grate. And, being square, makes cuts eaiser than a round drain cover.
    Then, you have the choice of either a conventional, pitched shower to a central drain, or doing a linear drain. You have more choices for floor tile with a linear drain since you don't have to accommodate multiple slopes - you slope the entire shower pan in one direction to the drain (well, you can do a reverse pitch if the linear drain isn't at the wall).
    The key to any of these is the workmanship and following one of the accepted industry practices (check out the TCNA handbook). Check out the videos on the Wedi and Schluter websites. Once you have tile installed and grouted, Wedi's foam boards (and KerdiBoard, if you choose to use it verses their sheet membrane) both are quite stiff.
    There are other well regarded paint on waterproofing systems...read a little here on some other threads with search, and you'll get various opinions on them.
    Jul 2009
    North Vancouver, BC
    What do you mean by best?
    If you are looking for thin membrane then Kerdi is the best. Only 8mil thick. This will make life easy for you installing.
    If you want fast then Kerdi Board or Wedi Board is the best. You get nice lightweight backer boards that flex. You can carry all your board up in one go.
    If by best you mean lowest Perm Rating in the industry then the sheet membranes from Noble Company win every time.
    If by best you mean longest warranty then Hydro Ban and Red Guard win with a 25 year warranty.
    Each shower needs to be specified around the time line and skill set of the installer.
    JW
    "When it's Perfect. It's good Enough." - John Whipple ...................... Q: Who are the Top Ten Bathroom Designers for 2010-2012..? ANSWER
    Contact Info: Email jfrwhipple@gmail.com Phone: 604 506 6792 Alternate Email: info@byanydesign.com
    Jul 2009
    North Vancouver, BC
    Default Best Shower Pan Material
    Here is a look at my new favourite waterproofing product. It's called Ardex 8+9.
    Another thing to consider when choosing a system is where the drain is located. If the drain is tight to one wall like this Tub to Shower conversion we prepared here in Vancouver a liquid or cementious membrane is "best".
    The reason for this is that it is hard to get the membrane to lay down nice if it is not in the center of the shower. You will see a flash of Blue around the drain. That is a Noble Flex Flashing.
    Lifetime drain connection warranty on this product if I'm not mistaken. 1 1/2" drain flashing used.
    Allows me to give excellent weep hole drainage and a topical system for the most part.
    This is a Noble Company Point Drain. Made by Sioux Chief. Outstanding weep hole drainage. 4 bolts not three. Multiple weep hole locations. Solid drain.
    You can see I used some Hemp Cord to keep the weep holes free.
    Designer P Gravel - this p gravel layer further protects the weep holes from blocking up with the mortar layer.
    Ready for tile. The hemp cord gets trimmed flush once dry. These little strands will dissolve leaving tunnels for the water to migrate faster directly to the weep holes.
    The Best Shower Pan is a system or a complete design.
    We self inspected this shower with a 71.75 hour flood test. Passed with flying colours.
    Which ever system you choose make sure the flood test gets preformed. 15 minutes is all that is require in much of the States - 24-72 hours is what is required for proper test results. It's your shower - make sure it's flood tested.
    JW
    Jul 2009
    North Vancouver, BC
    Default Best Drain for shower pan
    If you are using little tiles like these 2"x2" tile then a little forgiveness is nice. The Kerdi drain allows some wiggle room at install time. This is small barrier free shower system in Vancouver and was prepared using a hybrid approach of Ardex 8+9 and Kerdi.
    If you contact Ardex you can get a ten year warranty system with this approach. Twice the warranty that Schluter or Kerdi give out by themselves. And the kicker is you can use better thin-sets!
    JW
    Jul 2009
    North Vancouver, BC
    Default Best strength in shower pan liners
    On a busy job site with multiple trades everywhere the "Best" Shower pan liner is this stuff. Noble Seal TS or Noble Seal SIS. 30 mil thick (thickness of your bank card) and bondable to the substrate and tillable if set over a proper substrate.
    With multiple niches and a floating bench I prefer liquid or cementious membranes. So heavy protection down low and ease of application up high. Lapping the second over the first (not shown in this picture) is key to success and should happen above the height of the curb.
    As with all our projects this shower was flood tested and inspected by a Vancouver Plumbing Inspector.
    Jul 2009
    North Vancouver, BC
    Default Best Price on Shower Pan
    If "Best" is price driven then an old school liner takes the cake.
    This shower was prepared as cheap as possible. A simple 30mil liner from Master.
    This basic could be improved with one of Noble Company's premium 40 mil liners.
    The shower was flood tested for 3 weeks. When there are lots of guys working on a home the safest thing for the shower is to keep it full of water! This way it does not become a work zone or a tool drop location. You would think that is common sense - but you would be wrong...
    JW
  1. New Tub?Shower Installation
    By Al Pine in forum Shower & bathtub Forum & Blog
    Last Post: 03-20-2012, 06:09 PM
  2. Shower pan installation
    By pdwilly in forum Shower & bathtub Forum & Blog
    Last Post: 11-01-2009, 01:13 AM
  3. Shower installation
    By slanderman in forum Plumbing Forum Discussion & Blog
    Last Post: 08-11-2007, 10:55 PM
  4. Shower arm installation
    By dogs01 in forum Shower & bathtub Forum & Blog
    Last Post: 03-27-2007, 03:00 PM
  5. Shower Pan Installation
    By elgato in forum Shower & bathtub Forum & Blog
    Last Post: 01-27-2007, 10:46 PM
