Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Double / Triple Security Measures running Gas Outdoors
  1. #16
    Mar 2011
    Houston, TX
    They may steal your Generator, but the gas may take awhile. A Shotgun with 00 works very well if you are home. (Warning Don't use steel shot around gas)
    Put a quick disconnect , so when they take the gen the gas will be shut off automatically.
    Or use a device like Jim mentioned.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  2. #17
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    All POV taken. Thanks all.
  3. #18
    quote; (Warning Don't use steel shot around gas)
    And since environmentalists are trying to eliminate lead shot in the environment, why would you have anything other than steel shot in the gun?
  4. #19
    Aug 2009
    South*East
    Could be he just took apart a 4" leaded joint and didn't have any other use for the lead.
    John
  5. #20
    Mar 2011
    Houston, TX
    I believe that the steel bird shot should be used for bird hunting around wetlands.
    Lead Buck shot is still available , and a lot of deer slugs are lead also.
  6. #21
    quote; Lead Buck shot is still available
    No impact on the environment, as long as you hit the buck will ALL the shot.
  7. #22
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    I have the excessive flow "fuses" at the shutoffs to my gas appliances. Out of curiosity, I tested them during installation and they do close with wide-open flow. Haven't had one trip yet.
    Has anyone had nuisance tripping with them?
    Another thing you can add to prevent things going boom in the night is to add an automatic earthquake shutoff. Probably more likely here in CA than in DC, though.
  8. #23
    Aug 2011
    Santa Clara, CA
    To quote Ronald Reagan, "It came out of the ground, it can go back into the ground"...
  9. #24
    Mar 2011
    Houston, TX
    Quote Originally Posted by bluebinky View Post
    That goes for Used Motor Oil also, So Grandpa would say in the day.
  1. Sewer ejector basin outdoors - how far from house?
    By Seattle in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2011, 05:38 AM
  2. Adding an outlet outdoors
    By Bubba25 in forum Electrical Forum discussion & Blog
    Last Post: 12-13-2009, 12:26 PM
  3. ceiling fan blades for outdoors
    By Lee Tanner in forum Electrical Forum discussion & Blog
    Last Post: 02-26-2009, 04:56 PM
  4. Grundfos CU 301 installed outdoors w/ no cover.
    By Singlecoil in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-22-2008, 11:57 AM
  5. HVLP Paint Sprayers - outdoors
    By rdtompki in forum Remodel Forum & Blog
    Last Post: 12-11-2007, 09:28 AM
