Results 1 to 7 of 7
Thread: GE Wall units.. no more heat pumps?
    Plumber jimbo's Avatar
    Default GE Wall units.. no more heat pumps?
    My whole condo complex has GE AJ...series wall air conditioners. As our forced air heaters are dying with no repair/replacement seemingly available, some owners had put in AJ units with heat pump feature. Apparently they no longer are made like that, just straight cool. Anyone have different info???
    Our FAU are Suburban Dynaceil. I believe they went out of business shortly after selling Pardee Builders several hundred units! For at least 15 years we have been told that there are no parts...heat exchangers, control board, etc. available. Because of how they are installed...they are pancake units to fit in a shallow soffit...and direct horizontal flue and combustion intake.....there is no replacement available from anyone.
    Any other ideas?
    In the trades Dana's Avatar
    Jan 2009
    I'm a fan of mini-split heat pumps for their quiet efficiency & comfort, but I'm not sure if they'll work in this situation. There are ducted cassette mini-air-handler options for some amount of distribution between rooms, flush-mounted ceiling cassettes that fit between joists, floor mounted wall units (about the size & shape of a small wall-furnace or fin-tube convector) as well as the more common 12" x 12" x 40" wall-blobs.
    The outdoor units are often wall-hung in multistory buildings but that's not always an option for aesthetic reasons. The refrigerant line max-lengths usually mean ground mounting pretty much stops at the third story.
    Heating mode efficiency in a San Diego climate would have a comparable or even better operating cost than 83% efficiency natural gas furnaces.
    They're not super cheap, but they ARE super comfortable, since the modulate and track the load for very stable room temps.
    We have approved a couple of homeowners to install mini-splits. Each unit has a patio or balcony, and the main electric panel is right there to connect the outdoor unit two.
    Aessthetically, we would never approve to change out the AJ sleeves to an AZ.....we jealously guard the integrity of the walls, and the outside look. These are all small one and two BR units. Same goes for a wall-hung.
    We are recommending that even the electric heat AJ is probably the best alternative. Least expensive, and although our electric rates are high, overnight winter temps seldom below 45, daytime in the high 60's. We don't really need no steenkin' heat!!!!!!!!!
    Jan 2009
    " We don't really need no steenkin' heat!!!!!!!!! "
    Rub it in jimbo, just keep rubbin' it in... ;-)
    My mid-winter highs are well below your 99% outside design temperature.
    Water heater based fan-coils can sometimes be reasonable solutions to tiny heat loads too, but it doesn't solve the AC issue (which isn't so severe in your neighborhood either, except for maybe the top floor units/rooms.)
    DIY Junior Member Failure2Comply's Avatar
    Sep 2012
    Virginia, USA
    GE "Zoneline" PTAC units are in my opinion the finest made. It is tough to beat their quality and warranties.
    But we are stuck with 'AJ" sleeves, no possibility to install an 'AZ' sleeve.
    Sep 2012
    Virginia, USA
    I have not dealt with one in a while so not sure.
  1. Any opinion on Goodman heat pumps?
    By gplumb in forum HVAC Heating & Cooling
    Last Post: 07-15-2013, 07:45 PM
  2. 2 pumps in one well ??? Heat Pump and House
    By dancour in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-27-2010, 06:19 AM
  3. OT: Efficieny of Boilers vs Heat Pumps
    By chefwong in forum Boiler Forum
    Last Post: 05-01-2010, 03:10 PM
  4. Heat Pumps/Well Pump Problem
    By plantnerd in forum HVAC Heating & Cooling
    Last Post: 12-12-2009, 06:24 PM
  5. Heat Pumps After Thermostat Replacement
    By dickcarr in forum HVAC Heating & Cooling
    Last Post: 03-10-2009, 05:18 PM
