Results 1 to 7 of 7
Thread: Installing Cementboard New Tub
    DIY Junior Member swiederin's Avatar
    Apr 2012
    Iowa
    Default Installing Cementboard New Tub
    I am remodeling my old house bathroom and I am installing a new tub and shower base. My wife will be taping the cement board and drywall and wants me to install the board at the ceiling first and work down toward the new tub and shower base. She does not want to stand in the new tub and base and work. Is this a no-no? I had planned to start at the bottom and work up and cut the last piece to fit the ceiling. Opinions and comments appreciated.
    Sep 2009
    Seattle. WA
    Drywall and similar sheet goods are traditionally installed from the top down, and for good reason. There is
    neither rule of law nor physics which would preclude doing it the other way. Are you actually putting board
    on the ceiling, or just butting up to it? I do not understand your wife's issue: the tub and base certainly must
    be installed before the cement board, and much work while standing in a
    new tub/shower base is inevitable. Suitable protective measures should be employed. There are usually good
    reasons for putting the board joints one place rather than another, and the layout should be worked out before
    work commences. Talk to your wife and get it worked out, nicely.
    Ceilings are done first almost all of the time.
    the wall sections help to hold the ceiling up on the corners.
    You can reverse that, but it makes the job "much" harder.
    Jul 2009
    North Vancouver, BC
    Default Protect your tub with Ram Board
    The main reason for boarding the ceiling first is so you can get your fasteners in easier. If the wall board goes up first then there is less of the 2"x stock to screw or nail to on the ceiling.
    Your ceiling framing should be on 12" center not 16".
    You can use Ram Board to protect the tub. We love this stuff. Pick up a roll and protect the walkways and what ever else might get trashed.
    JW
    Michel Cleark MichelCleark's Avatar
    Nov 2012
    2131 Blackstone Landing Dr, Kissimmee, FL 34758
    Yes, definitely ceiling should come first. It will help for further wall boarding. I like the idea of Ram Board. It is really wonderful to protect my tub.
    Renovate old cabinets with espresso kitchen cabinets and add new look to your kitchen.
    No Mercy! No Pain!
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by MichelCleark View Post
    With the framing on the ceiling make sure you have them on 12" centres if your planning on tiling it and using cement board there.
    JW
    If you are installing the cement board on the ceiling you want to do the ceiling first.
    If you are installing on the walls I usually start at the bottom and work my way up. Cement board is heavy, and putting the first sheet on overhead and trying to start your screws and hope the sheet doesn't slip at all can be tough. I recommend starting at the bottom and put 1/8" gaps in between each sheet. Read the instructions. I recommend putting 4 mil plastic behind it, but not all cement board manufacturer's require it. I think Durock or Permabase are the easiest brands to install. Selectcrete is the absolute worst.
    I recommend protecting the tub and stepping in it (or on it). If you try to do it with a ladder, or something, you'll be at a bad angle and there's a chance the board will slip off and hit the tub. It's easier and safer if you can install it from in the tub.
    Jim
    Issaquah Tile Installation
    Issaquah Bellevue Seattle
  1. Any one installing these?
    By jimbo in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-01-2012, 02:28 PM
  2. installing new tub
    By janels in forum Shower & bathtub Forum & Blog
    Last Post: 12-14-2011, 06:51 PM
  3. Installing new tub??
    By BF750 in forum Shower & bathtub Forum & Blog
    Last Post: 10-09-2008, 09:41 AM
  4. Installing a toilet AFTER installing the tile
    By atroutcatcher in forum Toilet Forum discussions
    Last Post: 09-07-2007, 09:35 AM
  5. installing new tub
    By robyn205 in forum Shower & bathtub Forum & Blog
    Last Post: 11-05-2006, 01:28 PM
