Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: How do I hook up a Goulds 3/4 hp deep well jet pump with cross and control valve?
  1. #16
    Mar 2011
    Houston, TX
    Quote Originally Posted by Schimko View Post
    So I have a J7 3/4 hp Goulds pump. They also sold me the control valve and the cross piece. We had guessed at this with our first shot and think we had too much pressure going down my casing therefore blowing off my leathers. I read the pump book again today for the 5th time and have come to realize that I need to run my pressure switch off this control valve, which we did not do the first time. The pump book says it should have like 32 psi going down the casing. That seems easy enough to do. My question is how do the pipes run? Like from the cross to the tank to the control valve, or from the cross to the pump to the control valve? I have 3 holes on my pump. The one on top I believe is my main water line and the other 2 are for discharge? The hole in the middle is 1 1/4" and the bottom hole is 1" i believe. Can someone PLEASE help before it starts to freeze my dirt so I cant shovel it back into the hole?
    Attachment 17848Attachment 17849
    Why is there a tee in the Jet drive line ? Are you using it as a output ?
    Seems like it should be on the pump outlet, Or am I missing something ?
    if it was really "blowing off my leathers" then that must be a site to see. Please post pictures.
  2. #17
    DIY Junior Member Schimko's Avatar
    Sep 2012
    wisconsin
    Theres not a T in the Jet drive line. Theres a T on top of my casing.
    I wouldve loved to have been down there to take pictures of this event but I dont fit down my 2 1/2" casing.
  3. #18
    Mar 2011
    Houston, TX
    If it has a packer then the casing is the Jet drive line. Is it not ?
  4. #19
    Sep 2012
    wisconsin
    Yea I guess if you say it that way. Seems like everyone has their own verbiage for it.
  5. #20
    Mar 2011
    Houston, TX
    I am no expert, But seems to me that the only reason to have a tee where yours is, would be for a gauge to measure the Jet pressure.
    Normally if you are using a water pressure/flow regulator, then most likely it would have a Gauge on it.
    It sounds like you may have a valve that restricts the output of the pump to get the jet pressure up.
    That should work, but the valve needs to be closed some or the jet may never get enough pressure to get the water flowing.
  6. #21
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    It's hard to tell exactly what you have from the picture you posted. I'm going to try and keep this as simple as I can. On a deep well jet pump, you have a "DRIVE" line and a "SUCTION" line. The drive line is always smaller than the suction. Typically the drive line is 1" and the suction is 1.25".
    What you really need is a real well head, but since you have a 2.5" casing you can no longer buy the proper casing adapter (well head). If you could convert the 2.5" pipe to 3" you could use a goulds AWJ3 casing adapter and it would be much simpler.
    Just remember this-the suction pipe goes directly down to the jet. The drive pipe is the pipe that sends water between the casing and the jet-it's what the leathers are being used to divert into the nozzle of the jet.
    When running a multi-stage goulds jet pump the backpressure needs to be about 40-45 psi for a two stage. I would also recommend getting a real regulator and getting rid of that one you have. Look for the AV21 regulator. There is one made specially for horizontal pumps, I can't recall the exact model number off hand.
    [edit] OK, I just re-read your post. Your pressure switch has nothing to do with the jet pressure-leave it as is. It always needs to be connected to the "tank pressure", or the same pressure you have in your house lines. Normally they are connected to a port on the pump which reads the same pressure after the pump. Ditch the regulator you have and get an AV-21 regulator, it has a port on it to feed the line to the pressure switch.
    I'm leaning towards something beign wrong with the well itself. I normally run jet pressure from anywhere from 40 psi up to 80 psi with no problem, but 2.5" wells and leathers are a little different and it may be possible to flip the leathers. If there is a hole in the casing you would see the same symptoms.
    Good luck.
    Good luck.
  7. #22
    DIY Junior Member KBird's Avatar
    Mar 2013
    Maryland
    I have a 2" well casing and just purchased the same pump as Schimko. This was the original post:
    "So I have a J7 3/4 hp Goulds pump. They also sold me the control valve and the cross piece. We had guessed at this with our first shot and think we had too much pressure going down my casing therefore blowing off my leathers. I read the pump book again today for the 5th time and have come to realize that I need to run my pressure switch off this control valve, which we did not do the first time. The pump book says it should have like 32 psi going down the casing. That seems easy enough to do. My question is how do the pipes run? Like from the cross to the tank to the control valve, or from the cross to the pump to the control valve? I have 3 holes on my pump. The one on top I believe is my main water line and the other 2 are for discharge? The hole in the middle is 1 1/4" and the bottom hole is 1" i believe. Can someone PLEASE help before it starts to freeze my dirt so I cant shovel it back into the hole?"
    Ok, so now I'm reading in the Gould pump booklet that came with the pump that I need a "pressure control valve or some type of flow restrictor in the discharge line." They are suggesting an AV22KIT or an AV22 and a JDW tubing kit. My question is...does anyone have a diagram, schematic or something that I can reference to show the piping to/from the pressure control valve? I also need to know how to install the AV22KIT. Finding a diagram, photograph or schematic is like trying to find a needle in a haystack.
    Schimko, if you happened to take a picture of your finished Goulds J7 pump setup I would love to see what you did. Any advice from anyone would be greatly appreciated!
  8. #23
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Hi Kbird
    How deep is it to water in your well? If it is deeper than about 20' you are going to need a packer and a casing adapter to use both the 1" and 1 1/4" fitting on the suction of the pump along with the control valve you are talking about. If the water less than 20', you can plug the 1" suction from the pump and just use one pipe connected to the casing, and with one pipe suction you don't need the control valve.
  9. #24
    Mar 2011
    Houston, TX
    Quote Originally Posted by valveman View Post
    Hi Kbird
    Where I live we have water at 12-15 feet and still use Jets at 40 feet or so.
    Not sure why the poster posted a new question here, or why digging up dirt would be needed for a AV22KIT install on a above ground jet pump.
    Maybe I missed something.
  1. can I use a 3/4 hp dual cap control box on my 1/2 hp Goulds 10GS05 pump
    By fcbclan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-02-2012, 01:36 PM
  2. Deep well pump check valve
    By mmzullo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-21-2011, 12:06 PM
  3. Jet pump control valve adjustment
    By gardner in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-13-2009, 06:49 AM
  4. TP Valve Hook-up
    By DBS2071 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2008, 11:56 AM
  5. Replacing Sewage Ejector Pump/Control Valve
    By nogimmicksneeded in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-17-2007, 12:10 PM
