Results 1 to 8 of 8
Thread: Washer and Dryer moving upstairs - oak floors
Hybrid View
    Default Washer and Dryer moving upstairs - oak floors
    I'm considering moving my mother's washer and dryer upstairs where there's oak flooring. A leak would be really bad news so I'm probably going to put in a pan underneath the washer. I'm assuming this also must go to a trap, but since it won't (hopefully) get used much, if at all, what's the best way to keep that trap primed? As an aside, would it be legal to plumb it outside directly? That would be one less trap and vent to deal with and a one-time discharge outside shouldn't be a big issue.
    This is an old house (built in the early 50's) that has inadequate venting per today's standards. I could probably get to the one vent upstairs but it would likely mean tearing out plaster for two stories to get to above the flood plane of the things above. Would an AAV (I'm pretty sure they're approved where she lives) be a viable alternative? The inspector did allow me to use one when I put in a new shower for her a few years ago. If it makes any difference, she's on a septic system.
    Not sure how effective they are on a WM.
    I like the look of the Sioux Chief Ott boxes for washing machine supply/drain with the suppressors integrated. Who makes a decent washer pan? I've not looked around for one.
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    I just went thru this. The Sioux Chief box with arrestors is killer deal. Mount them together with the two gang cover. Here is a great pan:http://driptite.com/index.htm I am just going to drill a hole and drop it thru the floor into the crawl space. I would say just diverting it away is no more harmfull than a fire sprinkler test fitting outside. Of course, I am an electrician, and no plumber.
    Jun 2009
    Canada
    It would technically be for emergency use only, I'm not sure how this works out for your local code, but I would run it outside if I thought I could get away with it.
    I would never put my washer on a floor finished in oak anyways though.
    Well, at 85, and getting frail, doesn't want to move, having the WM on the same floor means not paying someone to do all of her laundry. You work with what you have...
    Jun 2009
    Canada
    I used an Ox Box in my basement bath/laundry room, I'm a big fan.
    DIY Junior Member 6t7gto's Avatar
    Jan 2010
    Bedford, Ohio
  1. Washer Dryer Hook Up Moving to Upstairs
    By skoby in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-06-2012, 03:08 PM
  2. Broken dryer on washer dryer combo
    By Kristoffer in forum Electrical Forum discussion & Blog
    Last Post: 12-14-2011, 11:37 AM
  3. Moving washer and dryer to basement
    By tmjacobs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2011, 05:56 AM
  4. Moving washer/dryer from kitchen to basement
    By tedeverson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2009, 06:44 PM
  5. Moving Washer dryer to Upstairs Bath
    By kess22b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2007, 08:51 AM
