Thread: Jet pump pressure
    DIY Junior Member Sam Downing's Avatar
    Nov 2012
    Maine
    Default Jet pump pressure
    I just replaced my 1/2hp jet pump with a1/2hp new pump, and the expansion/pressure tank (25gal) with similar size. I am drawing water, but only enough to run a single faucet and not enough to reach the second floor or power the first floor shower. The switch is set 20-40 as factory settings and the pressure tank is 25lbs. To increase my pressure is it simply increasing the switch settings to 40/60? That's where the trigger points were on the previous pump. My gauge is currently reading 25lbs.
    Thanks for your help
    Sam
    Moderator valveman's Avatar
    Mar 2006
    Yes all you need to do is increase the pressure switch setting. That is as long as your new pump can build that much pressure. You don't want to get close to the "max" pressure that pump can build.( check the pump specs) Depending on which 1/2 HP you have, the max pressure might only be 60 PSI. Which means you don't want to set the pump to shut off any higher than about 55 PSI.
    Feb 2011
    NW Ontario, Canada
    You will also have to increase the air precharge on the tank.
    Nov 2012
    Maine
    I called the vet for a house call in the morning.
    I'll enjoy a cold beer with my feet up til then.
  1. Low pressure, pump stays on - tank, pressure switch? Replace all?
    By applebach in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2011, 04:51 AM
  2. I think pressure switch is not receiving pressure from pump.
    By jeremytl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-04-2011, 06:26 AM
  3. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
  4. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
  5. ***Help***Pressure tank/pressure switch/pump
    By s4orce in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-28-2007, 02:11 PM
