Results 1 to 5 of 5
Thread: Lets' talk grout type
    DIY Member boardable's Avatar
    Sep 2012
    San Jose, Ca
    Default Lets' talk grout type
    So I am getting ready to grout my shower plan floor. Used botik eurothane grout on the walls and it turned out great. For the floor they did not have my color in a eurothane grout so now I am stuck with either using the same regular sanded grout I am using on my floor or using a epoxy grout from home depot. I like the eurothane grout because it helps in the water proofing. Does the epoxy grout do the same or is does it still absorb as much water as the regular grout. I just cant get the picture out of my head of water absorbing through the regular sanded grout. Yup loosing sleep lol.
    First, a properly built shower is waterproof BEFORE the tile is installed, so the grout type used shouldn't be a big consideration except for durability and reliability. Epoxy grout is a waterproof plastic, so no, once cured, it is not affected by water. Cement based grouts are somewhat porous and a sealer helps keep them clean. An epoxy grout does not absorb any sealer, so it's not useful.
    Sep 2012
    San Jose, Ca
    That is what I am wondering. PLus I used a kerdi pan and flood tested but like I said it is keeping me up at night. Also the fact that the foam may be a little flexible makes me want to use epoxy as well.
    When you spread the load out with the tile, denting the foam pan is not an issue at all! Epoxy grout requires careful cleanup (well, any grouting does, but epoxy is much harder to clean after it cures). Epoxy also tends to be a little shiney, which may or may not be an issue. Regardless, I'd go with either a conventional cement based grout or an epoxy. the epoxy shouldn't need any maintenance after installation, a cement based one will last as long or longer, but to look good, you likely would need to clean and seal it periodically. Depends on how much use the thing gets and the type of soaps and shampoos you use. Sealer won't waterproof the grout, but it helps prevent staining.
    Sep 2012
    San Jose, Ca
    Yea I think I am going with the epoxy. Cleaning grout is not apealing to me.
  1. Can we talk about trap seal primers in residential use?
    By speede541 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-15-2011, 08:54 AM
  2. Americans talk too much...
    By Ian Gills in forum Ian's Corner
    Last Post: 10-14-2010, 08:38 AM
  3. What is the difference between type L and type M copper pipe
    By Dom Z in forum Plumbing Forum Discussion & Blog
    Last Post: 08-09-2009, 09:39 AM
  4. Some pics to talk about
    By jaxbldginspector in forum Electrical Forum discussion & Blog
    Last Post: 02-17-2009, 04:46 AM
  5. Straight Talk About "On-Demand Tankless Water Heaters by A.O. Smith
    By SewerRatz in forum Tankless Water Heater Forum
    Last Post: 02-13-2009, 05:05 PM
