Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 82
Thread: New water softener system awaiting installation, few questions.
  1. #31
    Jan 2012
    California
    Home Depot and other home improvement stores typically do not sell adequate test kits. Get a Hach 5B test kit. It is a simple and accurate kit that is reasonably priced.
  2. #32
    DIY Junior Member marcelo73's Avatar
    Nov 2012
    Los Angeles
    Thanks for your input on pipe along concrete, I will fix that.
    Ditto, thanks for info on test kit I will search for it.
    M
  3. #33
    Nov 2005
    Central Florida
    A piece of wood etc. anchored to the concrete between the concrete and the tubing would be my way of doing it.
    Any thoughts about pressure-treated wood?
  4. #34
    Jan 2012
    California
    Unistrut with insulated clamp.
  5. #35
    Nov 2012
    Los Angeles
    Quote Originally Posted by Mikey View Post
    Exactly along the lines that I was thinking, replacing of course every couple of years as im sure even treated wood outdoor exposed would weather after time.
  6. #36
    Nov 2012
    Los Angeles
    This looks like a great fix, I will look into it.
  7. #37
    Nov 2005
    Central Florida
    Quote Originally Posted by marcelo73 View Post
    That's definitely the pro way to do it. Very pricey, but if you've got a buddy in the trades, she might be able to get you some short pieces of scrapped Unistrut. I've gotten a lot of it out of jobsite Dumpsters.
    Re treated wood, I'd heard that it and copper in contact don't get along, but the new treatments are copper-based and may be just fine.
  8. #38
    Nov 2012
    Los Angeles
    Yes it is a bit out of my budget, but definetly the pro way. I may just make some adjustments and run along the exterior of the house which is stucco, wait would stucco have same alkalinity effect that concrete does? The treated wood which is copper based might be the most economical.
  9. #39
    If it was me, I'd save a few bucks and a lot of worry it seems by using sch 40 PVC instead of copper and laying it right on the concrete. And an additional benefit is no one wants to steal plastic...
  10. #40
    Jan 2012
    California
    Actually, the material is surprisingly inexpensive. I personally always use 304 stainless since the cost for that is reasonable. Check out this link. McMaster Carr is expensive, but considering how cheap it is even through them, it is worth looking into.
    And they typically ship the same day.
    http://www.mcmaster.com/#strut-channel-systems/=kb9ghw
    http://www.mcmaster.com/#strut-channel-systems/=kb9hbv
  11. #41
    Nov 2010
    Maine
    If the piping is inside the building it can NOT be schedule 40 PVC for the supply lines.
  12. #42
    Nov 2005
    Central Florida
    That is the way to go, although the thought of cutting a bunch of 6" pieces with a hacksaw isn't appealing. The only place I looked for strut material was a local A/C supply house I use, but they only sold it in 10-foot lengths. We've got a McMaster Carr outlet here -- I generally don't even think about them because they tend to be expensive. I tried to see how much the cushioned clamps are, but their web site search seems to be steam-powered today.
  13. #43
    Nov 2005
    Central Florida
    I suppose that's "code" -- any idea what the reasoning is behind that?
  14. #44
    Nov 2010
    Maine
    If you have a Fastenall store around they sell Uni-Strut in 5' lengths
    PVC is not rated for supply distribution inside a structure. The problem is that PVC is not rated for temperatures above 185 degrees and if the PVC was only used for cold water it would be OK but sooner or later someone that didn't know the why;s and wherefore's would undoubtedly wind up using PVC for hot water with disastrous results.
  15. #45
    Most people would think that plumbers should know better... or their inspectors would catch the mistake, but then there is that part of PVC going in easier and quicker than copper and earning plumbers less money.
    Ummm this is outside behind or along side the house....
    Are we sure that Unistrut is made for outdoor applications and that the clamp rubber will stand up to the elements? Are you planning on anchoring the strut to the concrete? IIRC, Lowe's and Home Depot sells it. A couple short pieces of oak from a shipping pallet would last for decades but PVC tubing would be the best choice.
  1. Water Softener Installation?
    By prickett in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-18-2011, 07:53 AM
  2. Water softener WHES40 & Central Water Filtration System - Questions
    By reggiev6 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-16-2011, 10:57 AM
  3. Water Softener Self installation
    By chubyball in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-03-2009, 12:12 PM
  4. Water Softener Installation Question
    By vr_46 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-04-2007, 07:53 AM
  5. installation of a water softener
    By Greg in forum Plumbing Forum Discussion & Blog
    Last Post: 08-08-2005, 07:41 PM
