I don't understand why you are spending time messing with plaster. If the floor is reasonably flat, a toilet might need a couple shims to keep it from rocking before it is set on a new wax ring. Chances of coming out with better results using plaster are not very high.
If the floor is screwed up so bad the shims will not do the job, it's time to fix the underlying problem.
