Is there a little light flashing when water is used in the house?
Could be that either the meter cable at the turbine is out of the hole or the turbine is not spinning.
Make sure that the light is flashing when water is running.
I have an Autotrol Performa Valve with a 460i control. It has stopped auto regeneration. I can manually regenerate. Any idea where the problem is?
I checked for the flashing light when water is running in the house and it does flash when water is running. Are there any other things to try?
If the programming hasn't changed or you haven't changed it, I'd suspect the circuit board since the turbine is spinning with water flow and the light is blinking.
