Results 1 to 9 of 9
Thread: Autotrol Performa Valve with a 460i control
    DIY Junior Member jacktorgerson's Avatar
    Nov 2012
    Phoenix, AZ
    Default Autotrol Performa Valve with a 460i control
    I have an Autotrol Performa Valve with a 460i control. It has stopped auto regeneration. I can manually regenerate. Any idea where the problem is?
    Dec 2009
    Alaska
    Is there a little light flashing when water is used in the house?
    Could be that either the meter cable at the turbine is out of the hole or the turbine is not spinning.
    Make sure that the light is flashing when water is running.
    Nov 2012
    Phoenix, AZ
    Quote Originally Posted by Akpsdvan View Post
    Thanks,
    I checked for the flashing light when water is running in the house and it does flash when water is running.
    Nov 2012
    Phoenix, AZ
    I checked for the flashing light when water is running in the house and it does flash when water is running. Are there any other things to try?
    If the programming hasn't changed or you haven't changed it, I'd suspect the circuit board since the turbine is spinning with water flow and the light is blinking.
    Nov 2012
    Phoenix, AZ
    Thanks. Any suggestions where to look for a board?
    Jan 2012
    California
    Quote Originally Posted by jacktorgerson View Post
    http://www.****.com/itm/NEW-AUTOTROL...-/250533723952
    replace the **** with the famous site that rhymes with knee bay
    Any local or internet dealer, some big box stores and plumbing/pump supply houses, a few plumbers or well drillers
    Nov 2012
    Phoenix, AZ
    Default 360i
    WOW! looks like I can get one just about anywhere. Thanks for all your help.
  1. Autotrol 460i problem
    By rudyjr in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-10-2012, 10:55 AM
  2. 255 valve / 460i control
    By Tom Bond in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-26-2011, 06:59 AM
  3. Autotrol 255valve/460I valve
    By moisheh in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-01-2010, 06:10 PM
  4. Should air check valve in Autotrol 255 be full of water or air?
    By jfscullion in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-03-2009, 04:59 AM
  5. Should air check valve in Autotrol 255 be full of water or air?
    By jfscullion in forum Pumps and Tanks Well Forum & Blog
