Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Programming an 5600SXT for maximum effenciency
  1. #16
    DIY Member ByteMe's Avatar
    Nov 2012
    Midland Texas
    This is what i did using the figures from; http://www.caitechnologies.com/image...pecs/SST60.pdf
    Capacity = 30,000
    Hardness = 40
    Reserve = 120 gallons
    Days Override = 8
    Backwash = 5 minutes
    BrineDraw = 30 minutes
    Rapid Rinse = 8 minutes
    Brine Fill = 4 minutes (there is a sticker on the WS that says .5 gallon /1.5lbs)
    So, 30,000 grains / 6lbs should be 5,000 salt efficiency ?
    Can this bad boy softener do it well?
    I figure that I might get away with these reduced times because I have great pressure (I know the unit will restrict) and am dosing at such a low level. I figure worst case it doesn't work and I try a lower salt efficiency (re-figure everything again) and send Gary hate mail for being correct. Or I can bump up the BF setting to get me 7.5lbs and a 4,000 efficiency.
    BTW; a 47 minute regen is kewl
  2. #17
    Nov 2012
    Midland Texas
    Come on, no-one?
    Anyone else try settings like this? I want to hear your experiences.
  3. #18
    Jan 2012
    California
    Salt settings are more than just grains per gallon. Water efficiencies, hardness leakage, time between regenerations, etc all have to be considered. Systems can be set to as low as 3 pounds of salt per cubic foot, but the water quality is usually below customers expectations. 4 pounds per cubic foot is the minimum most companies will do so as to maintain quality, and 6-8 pounds almost ensures near perfect quality. Below is a hardness leakage chart. With all this being said, if you are happy with the results and you are efficient, then it is all good!
    My major problem is when companies set softeners to use 10-15 pounds of salt per cu. ft, this gets out of the reasonable efficiency range and ventures into unnecessary waste.
    Name:  capacity leakage.jpg
    An article written by one of the best minds in this industry (Chubb Michaud) explains it far better than I ever could. It goes into a detailed analysis and reasoning behind maintaining truly soft water vs. slightly hard water. http://www.wcponline.com/pdf/1203Michaud.pdf
    My system has a considerably longer regeneration time, approximately 105 minutes, but it is set to the exact application. It only regeenrates monthly at most, and the system is set with a smaller injector for various reasons that are not worth discussing here since it gets very wonky. I also run slightly longer backwash times since I am using KDF media as one of the filtration processes, this media loves to be backwashed regularly and aggresssively.
  4. #19
    Nov 2012
    Midland Texas
    I used data from the SST60 data sheet which is similar to yours but "better".
    Wonder what the chance is that the SST60 data is not really accurate.
    SST-60 C-100
    Leakage Leakage
    NaCl
    (#/CF) (ppm) (ppm)
    2 2.1 3.7
    3 1.3 2.1
    4 0.9 1.4
    5 0.7 1.2
    6 0.6 1.1
    7 0.5 0.9
    8 0.4 0.8
    9 0.35 0.7
    10 0.3 0.6
    12 0.2 0.5
    15 0.1 0.4
  5. #20
    Jan 2012
    California
    Hardness leakage is actually very comnplex, the charts are simple guidlines to help us understand the potential or likelihood of hardness leakage. Resin age, quality, fouling, flow rates, remaining capacity, etc. all have to be considered. For resideantial applications, most people are very happy with 10 PPM or less, commercial applications that require hardness <3ppm is where it gets exteremely complex, maintaining below this hardness requires considerabnly more expertise, fortunately this is not common and rarely an isue in residential sitiuations.
    My recommendation, use standard resin numbers and capacities, use no less than 4 pounds of salt per cu. ft., and you will be fine.
  1. Fleck 5600sxt, time change?
    By martinf55 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-07-2012, 08:12 PM
  2. Fleck 5600SXT Programming
    By mjdamore in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-18-2011, 08:49 PM
  3. Fleck 5600SXT whines when water runs
    By lihp in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-10-2011, 08:40 AM
  4. Fleck 5600SXT can't get back to all my settings??
    By Davisracing9 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-12-2011, 03:05 PM
  5. Fleck 5600sxt
    By hotrodjohn in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-21-2009, 02:55 PM
