Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Shallow Wall Cavity for Junction Boxes, Cut Back of Boxes or Surface Mount?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Shallow Wall Cavity for Junction Boxes, Cut Back of Boxes or Surface Mount?
    Hello,
    I need to install a few junction boxes in an old home. I've tried to use the standard old-work boxes, but they are too deep.
    I've considered cutting the back of the box, but not sure if this is acceptable. I'm also wondering if there is a decorative surface mount box available?
    Thanks in Advance!
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    No, the whole idea of the box is that it is enclosed when the cover is on...cutting the back off defeats that purpose. I've seen (and used) some shallow boxes. Keep in mind they limit considerably what you can put in them both in devices and cables.
    Sep 2006
    cold new york
    I was considering modifying a box by drilling two holes in the bottom for romex connectors. This would allow me to bring the wires into the box from a location other than the back of the box. I could then make a new back for the box that could be held on by a couple of small bolts and washers.
    I can't seem to find a shallow box elsewhere so am considering options.
    Gore Vidal.
    Jan 2008
    Another option is a surface-mount box extender like a leviton 6197
    http://www.levitonproducts.com/catalog/model_6197.htm
    Sep 2006
    cold new york
    The problem is depth of the conventional boxes. When they go into the wall they hit studs, or sheathing. I only want to join two pieces of 12-2 together so don't need much space.
    This does raise the question about the amount of open space in the plastic boxes around where the wires enter the box. The plastic tabs leave quite a bit of open space once the wire is pushed into the box, which makes me wonder what the problem is with not having a back on the box?
    Gore Vidal.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    How deep is the cavity? A shallow 1900 box, also called a four square, is only 1 1/8" deep. You could also surface mount it, or come in the back of a wire mold box.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    Quote Originally Posted by molo View Post
    There is no "conventional" box. Cut-in boxes come in all differeent depths.
    PLEASE stop wondering this. You are questioning 125 years of code changes. The box needs to be in tact for a reason!
    WHY are you coming into the back of the box? NM cables enter the bottom of every plastic cut-in I have ever used.
    May I ask why you have to splice these cables in a finished wall???
    Sep 2006
    cold new york
    Quote Originally Posted by ActionDave View Post
    Thanks Dave,
    I'll look for those boxes.
    Gore Vidal.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    You do not need boxes to splice NM.
    There are recently approved spice devices that cost about $6. They have a pretty solid grip on the cable such that the join is not going to be pulled apart, which is the key reason that just wire nutting in a wall cavity is illegal.
    And just how deep is the wall void that you are working with?
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Quote Originally Posted by Homeownerinburb View Post
    Do you have a link for this item?
    Jun 2007
    North Carolina
    Quote Originally Posted by big2bird View Post
    http://www.homedepot.com/buy/tyco-el...1116377-2.html
    but remember that it has to be accessible
    quote; remember that it has to be accessible
    ANd the easiest way to make it "accessible" is to make the connection in a box. So he is back to his original question, and the answer is a shallow box, but since an "old work box" with toggles does not come in a shallow pattern, he needs the sheet metal "T" grips that fit into the opening on either side of the box, then bend around the side edges to hold it in place.
    Sep 2006
    cold new york
    The local hardware has a plastic box that is only 1" deep. It has a knockout on the top and bottom. It doesn't have the screw-tightened tabs that the "old-work" boxes do.
    Gore Vidal.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    You may not think you need that much room but the required space is specified by the electrical code. For 2 12-2 cables without a device you need at least 5*2.25 cubic inches. with a device you need at least 7*2.25.
    Jan 2008
    I'd be curious to see what you are working on, as all the old houses around here used "real" 2"x4" studs with lath and plaster walls. There is just as much space inside those walls as are found in most new construction today. Maybe it's just a matter of putting the box somewhere other than the exact location that you have looked at.
  1. What is the ~purpose~ of laundry boxes......
    By chefwong in forum Plumbing Forum Discussion & Blog
    Last Post: 09-14-2011, 06:12 AM
  2. PVC boxes
    By Geoff K in forum Electrical Forum discussion & Blog
    Last Post: 07-28-2009, 06:33 PM
  3. plastic or metal junction boxes
    By Master Brian in forum Electrical Forum discussion & Blog
    Last Post: 01-17-2009, 10:30 PM
  4. ground electrical boxes
    By geandham in forum Electrical Forum discussion & Blog
    Last Post: 01-29-2008, 04:11 AM
  5. Plastic boxes?
    By projectorguru in forum Electrical Forum discussion & Blog
    Last Post: 12-11-2007, 02:05 PM
