Results 1 to 15 of 24
Thread: Shallow Wall Cavity for Junction Boxes, Cut Back of Boxes or Surface Mount?
Hybrid View
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Shallow Wall Cavity for Junction Boxes, Cut Back of Boxes or Surface Mount?
    Hello,
    I need to install a few junction boxes in an old home. I've tried to use the standard old-work boxes, but they are too deep.
    I've considered cutting the back of the box, but not sure if this is acceptable. I'm also wondering if there is a decorative surface mount box available?
    Thanks in Advance!
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    No, the whole idea of the box is that it is enclosed when the cover is on...cutting the back off defeats that purpose. I've seen (and used) some shallow boxes. Keep in mind they limit considerably what you can put in them both in devices and cables.
    Sep 2006
    cold new york
    I was considering modifying a box by drilling two holes in the bottom for romex connectors. This would allow me to bring the wires into the box from a location other than the back of the box. I could then make a new back for the box that could be held on by a couple of small bolts and washers.
    I can't seem to find a shallow box elsewhere so am considering options.
    Gore Vidal.
    Jan 2008
    Another option is a surface-mount box extender like a leviton 6197
    http://www.levitonproducts.com/catalog/model_6197.htm
    Sep 2006
    cold new york
    The problem is depth of the conventional boxes. When they go into the wall they hit studs, or sheathing. I only want to join two pieces of 12-2 together so don't need much space.
    This does raise the question about the amount of open space in the plastic boxes around where the wires enter the box. The plastic tabs leave quite a bit of open space once the wire is pushed into the box, which makes me wonder what the problem is with not having a back on the box?
    Gore Vidal.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    How deep is the cavity? A shallow 1900 box, also called a four square, is only 1 1/8" deep. You could also surface mount it, or come in the back of a wire mold box.
    Sep 2006
    cold new york
    Quote Originally Posted by ActionDave View Post
    Thanks Dave,
    I'll look for those boxes.
    Gore Vidal.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    Quote Originally Posted by molo View Post
    There is no "conventional" box. Cut-in boxes come in all differeent depths.
    PLEASE stop wondering this. You are questioning 125 years of code changes. The box needs to be in tact for a reason!
    WHY are you coming into the back of the box? NM cables enter the bottom of every plastic cut-in I have ever used.
    May I ask why you have to splice these cables in a finished wall???
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    You do not need boxes to splice NM.
    There are recently approved spice devices that cost about $6. They have a pretty solid grip on the cable such that the join is not going to be pulled apart, which is the key reason that just wire nutting in a wall cavity is illegal.
    And just how deep is the wall void that you are working with?
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    Quote Originally Posted by Homeownerinburb View Post
    Do you have a link for this item?
  1. What is the ~purpose~ of laundry boxes......
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-14-2011, 06:12 AM
  2. PVC boxes
    By Geoff K in forum Electrical Forum discussion & Blog
    Last Post: 07-28-2009, 06:33 PM
  3. plastic or metal junction boxes
    By Master Brian in forum Electrical Forum discussion & Blog
    Last Post: 01-17-2009, 10:30 PM
  4. ground electrical boxes
    By geandham in forum Electrical Forum discussion & Blog
    Last Post: 01-29-2008, 04:11 AM
  5. Plastic boxes?
    By projectorguru in forum Electrical Forum discussion & Blog
    Last Post: 12-11-2007, 02:05 PM
