Results 1 to 2 of 2
Thread: Heat Pump-Air Handler question
    DIY Junior Member jfls49's Avatar
    Nov 2012
    Prospect, PA
    Default Heat Pump-Air Handler question
    I have a 12 year old Bryant Heat Pump, 10 Seer, 3.5 ton. The reversing valve is crap. Right now I am running the heat in Emergency mode (electric furnace) until I fix it.
    Ive been on www.ingramsairandwater.com and located a 13 SEER 3.5 ton Goodman unit with matching air handler. My question: is it reasonable to go with same 3.5 ton system I had before without going to all the trouble to do a load calc on the house if I am getting the air handler with the variable speed fan? Wouldn't the variable fan speed settings allow me to program the desirable cfm moving through the house.
    Thanks for any advice
    Jfls45
    Without running some calculations, it's impossible to say, but 3.5T would heat and cool a quite large house. In the summer, was the humidity level in the house comfortable? If it got cold, but it was still clammy, that's an indication that the unit is oversized. A variable speed air handler helps, but that can't overcome an oversized unit's short cycling if it is oversized.
  1. Comparing Heat Pump & Coil / Air Handler Brands
    By DataDiva in forum HVAC Heating & Cooling
    Last Post: 10-16-2011, 05:54 AM
  2. covert three handler shower faucet to one handler
    By oz19454 in forum Shower & bathtub Forum & Blog
    Last Post: 07-10-2010, 04:54 PM
  3. Trane XE1000 matching air handler/heater question
    By rcfunk in forum HVAC Heating & Cooling
    Last Post: 05-17-2009, 07:16 PM
  4. Heat pump question
    By southernnaturelover in forum HVAC Heating & Cooling
    Last Post: 11-17-2007, 08:29 AM
  5. Heat pump question
    By fordfitz in forum HVAC Heating & Cooling
    Last Post: 09-14-2007, 06:42 PM
