Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Where to Purchase Toto Ultramax Toilet (CST853S)
  1. #16
    Apr 2012
    New York, NY
    Quote Originally Posted by Mazcar View Post
    So, any chance you remember the name of that great local plumbing supply house in Austin the guy said was cool? That yellow page list is pretty long.
    He said he got a good deal at Josco Plumbing Supply. www.joscoshowroom.com They have a couple of plumbing supply locations and a showroom. Looks like they are Toto fans. If you know the model number and color of the item you want, I would call one of the non-showroom locations (click on "wholesale location" on their web site) and talk price and availability. Their prices might be the same at the showroom, or they might not be...
  2. #17
    DIY Junior Member Mazcar's Avatar
    Jan 2013
    TX
    I know I pre-thanked you, but THANKS! I picked up a C744EL-01 (C744SL) elongated ADA Drake with a 1.6 tank and a generic seat for $238, including tax. That's the exact same price as a Kohler at HD. The website says it's ADA height; not universal height. So, I hope it's not too tall. Josco is cool and non-judgmental towards DIY'rs. I'll be back.
    Okay, to hijack my own message:
    If my toilet flange is just floating up from the netherworld, should I stuff steel wool or something around it for roach or varmint control? The flange appears to be connected to a cast iron pipe that goes down into my foundation.
    Thanks again!
  3. #18
    Normally, properly installed, a toilet flange is sitting on top of the finished floor (no gaps!) and anchored to the floor. With a CI flange, there's normally enough integrity where you can get by without it being fully supported on the edges, but if it is TOO high, the toilet won't sit flat on the floor and would rock on the flange. This can be a major problem. If the toilet does fit and sits flat during a dry fit (it might need a shim or two if your floor isn't perfectly flat, that's okay, but make sure to use them if needed!), then you could pack that gap with something like hydraulic cement, caulk, or your steel wool, if you like...
  4. #19
    Apr 2012
    New York, NY
    Glad to hear the good feedback about Josco! That's a good price, and it's nice to hear again that they're nice folks. Thanks for letting us know about that!
    As to the flange, I'm assuming that this is a replacement toilet; if the flange worked with the other one, it should work with this one, no worries. And as Jim says, stuff away! Of course, I would secure the toilet to the floor with a little bead of polyseamseal, and you can do that all the way around, depending on the requirements in your jurisdiction. That will help keep the varmints and vermin from heading out into your bathroom.
    The Drake II universal height puts the lip of the bowl 16 1/8" off the floor. The Drake ADA height is 16 1/2". I don't think you will find that the 3/8" difference feels too high (or for what it's worth is even noticeable), so I think you made a good choice!!
    Thanks for the update!
  1. Replies: 9
    Last Post: 10-12-2012, 04:27 PM
  2. Toto UltraMax still the recommended toilet
    By GeronimoDF in forum Toilet Forum discussions
    Last Post: 01-01-2011, 07:55 PM
  3. Toto toilet purchase
    By Larry Caskey in forum Plumbing Forum Discussion & Blog
    Last Post: 04-23-2009, 09:38 AM
  4. Which TOTO Ultramax Toilet?
    By rsmith99 in forum Toilet Forum discussions
    Last Post: 11-07-2008, 09:42 AM
  5. Ultramax Toto toilet in the corner?
    By amanhaus in forum Toilet Forum discussions
    Last Post: 02-02-2005, 06:39 AM
