Results 1 to 6 of 6
Thread: Water tank - beginner's question
    DIY Junior Member tksattler's Avatar
    Nov 2012
    Minnetonka, MN
    Default Water tank - beginner's question
    Okay - so I'm trying to remove a pressure tank from a water well. It's old - very old. The fittings are extremely tight, and I don't know which way to try to turn them. Before I make things worse, could someone advise? I know some fittings can be backwards - clockwise instead of counter clockwise. I'm referring to the actual giant nut that attaches to the tank on both sides. Obviously, I'm not exactly sure what I'm talking about Thanks much for any help!Name:  DSCN9006-001.jpg
Size:  61.4 KBName:  DSCN9005-001.jpg
    Don't know for sure, but that big 'nut' next to the tank wall may be welded in and you might not get it off. While there are some, it's rare in general plumbing that you'd have a left-hand thread. You'd probably be better off taking the stuff off further out.
    There are very FEW fittings which have a left hand thread, and none of yours do. BUT, none of the fittings in your picture can be taken apart, either, without a union somewhere or cutting the pipe.
    Feb 2011
    NW Ontario, Canada
    ...or cutting the pipe.
    Ja, time for the Sawzall®. There is nothing there worth saving.
    Aug 2009
    South*East
    The big nut next to the tank is a bushing. It's not welded in.
    John
    Nov 2012
    Minnetonka, MN
    A hack saw did the job. Very satisfying. Thanks for all of your advice.
  1. Water Heater Tank Question
    By cowboyjosh78 in forum Water Heater Forum, Tanks
    Last Post: 01-30-2014, 10:47 AM
  2. water tank question
    By chopped in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-07-2012, 06:30 AM
  3. Water Heater Tank Question
    By cowboyjosh78 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2010, 01:49 PM
  4. Hot Water Tank Vent Code Question
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2009, 08:38 AM
  5. Distance to Water Tank Question
    By statjunk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2007, 09:47 AM
