Results 1 to 9 of 9
Thread: 3" Toilet Drain
    DIY Junior Member KShirriff's Avatar
    Nov 2012
    Tuscaloosa, Al.
    Default 3" Toilet Drain
    I have a toilet drain on the 2nd floor directly above a 2x6 wall on the 1st floor. Can I run the 3" drain from the toilet flange straight down to the basement without any elbows at the top and tie into the horizontal drain line? I have a 2" vent tied into the 3" pipe about 18" below the toilet flange and vented up throught the roof. Someone said that they think this design might suck the water out of the toilet trap. Is this true?
    That's a really long drop but it won't suck the toilet trap dry with a vent. Not sure if that would meet codes...just don't know.
    It doesn't matter whether it drops straight down or has a few bends.
    Hopefully the bowl "does" siphon when you flush. The fill valve refills the bowl after a flush anyway. I would have no problem with a toilet drain run straight down. Wait..........I've done hundreds that way.
    Nov 2012
    Tuscaloosa, Al.
    should I put an elbow in it and offset it over and then down?
    Nov 2012
    Tuscaloosa, Al.
    Here is a pic Name:  plumbing.jpg
    Nov 2012
    Tuscaloosa, Al.
    going to reroute the vent at a 45 degree
    Nov 2012
    Tuscaloosa, Al.
    Thanks Terry
    Running the vent for the toilet on a vertical or a 45 is a good idea.
    Apr 2012
    New York, NY
    I was going to say that you could replace that combo with a Y for the vent, which is effectively what they are saying above.
  1. Connect toilet directly over main drain. 3" clearance under subfloor to top of drain.
    By zx6e in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2012, 09:05 AM
  2. Slope requirement on 3" horizontal drain - 1/8" or 1/4" per foot? Drain design?
    By Kubota_Kid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2012, 11:47 AM
  3. toilet drain 3" or 4"?
    By zxed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-02-2009, 08:08 AM
  4. 4" PVC for toilet drain - help
    By Steve89GTA in forum Toilet Forum discussions
    Last Post: 12-13-2008, 08:15 AM
  5. Toilet w/3" flush valve into 3" drain pipe
    By Jerry Ryan in forum Toilet Forum discussions
    Last Post: 08-21-2007, 06:51 AM
