Results 1 to 3 of 3
Thread: over thinking tub installation?
    DIY Junior Member blove1344's Avatar
    Sep 2012
    New Cumberland,PA
    Default over thinking tub installation?
    I'm in the process of installing a Sterling tub and surround. The tub is ready to go in but I'm having issues.
    In dry fitting the tub I found one corner slightly off level and should be raised a little. The back length is perfect
    and the other end is good. I am planning to use a morter bed and that is where the problem comes in. In my
    way of thinking, since you can't shim after the tub is in, I thought I would locate all the tub legs on the floor
    then add appropriate shims at the low legs and try to equal them out over the course of the tub length then add
    the morter and set the tub, avoiding the area where the legs would sit. Thus ending up with all legs sitting firmly
    on the floor, some with shims, and the morter would fill in all the undertub voids thus providing a stable tub base.
    Is this over the top or am I going about this the wrong way?
    Thanks for your help.
    Jan 2008
    Figure out exactly where the shims needs to be and adhere them to the floor with a dab of adhesive, then place the mortar piles and set the tub.
    Sep 2012
    New Cumberland,PA
    Thanks. It will take some time but I think in the long run thats the best way of doing it. Thanks for the confirmation.
    I needed someone with experience to give me some confidence.
  1. Thinking of upgrading
    By patrick88 in forum Computers and Stuff
    Last Post: 05-17-2012, 03:51 PM
  2. I'm thinking about this tub..
    By trinitony in forum Shower & bathtub Forum & Blog
    Last Post: 08-30-2010, 11:10 AM
  3. thinking about purchasing saniflo
    By riosgrande in forum Toilet Forum discussions
    Last Post: 03-24-2010, 01:47 PM
  4. Thinking of going tankless hot water
    By patrick88 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-26-2008, 08:11 PM
  5. Thinking of getting a ToTo 744, maybe problems??
    By stash in forum Toilet Forum discussions
    Last Post: 09-29-2005, 10:44 AM
