Results 1 to 5 of 5
Thread: Moen Posi-Temp Shower Faucet
    DIY Junior Member ptim's Avatar
    Nov 2012
    Florida
    Default Moen Posi-Temp Shower Faucet
    Very much a noob here. I have a Moen shower faucet, that has an issue, when you turn the water on, start spinning right to left, going through cold water, then into hot, as it starts its fine, but when it gets half way, the water get slower coming out, and the handle kinda gets easier to turn, almost like it gets loose. I took the handle off, but not all the way, to the valve, the plastic parts look fine, could the valve be bad.
    Plus its starting to leak.
    Most shower valves don't do just cold, but may get to all hot. So, you've got water coming through from both the hot and cold supplies but when you get closer to the hotter end, you start to shut off the cold. Using both supplies will produce more potential volume than just one (in this case the hot).
    In the Trades Towers Plumbing's Avatar
    Nov 2012
    Salt Lake City, UT
    Sounds like a Moen positemp valve cart 1222. That cart has a ball that moves back and forth depending on pressure to keep the water at the same temperature. Overtime, if the valve is not used alot, the ball can stick. This creates the effect you are describing. Sometimes taking out the cartridge and slamming it on a counter top can break the ball free, then use a silicone spray to keep it lubed or you can call Moen and get a new cart.
    DIY Junior Member chopped's Avatar
    Oct 2012
    Not to Hi Jack this thread but I found it after posting mine.A quick question for me is there a NON temp valve replacemtn for this? Thanks..
    Plumber jimbo's Avatar
    Quote Originally Posted by chopped View Post
    No. The Positemp was the improved version of the older non-pressure-balanced, "pull-out" Chateau. But NONE of the parts are not interchangeable and it would be a code violation to take out the posi and replace it with an old style valve.
  1. Do all Moen Posi-temp shower handles have stoppers?
    By djscrib in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2012, 05:40 AM
  2. Moen Posi Temp shower valve adjustment question
    By jgulley31 in forum Toilet Forum discussions
    Last Post: 02-09-2012, 04:47 PM
  3. Moen Posi-Temp 1222B Shower Cartridge
    By SteveMar in forum Shower & bathtub Forum & Blog
    Last Post: 08-11-2011, 02:09 PM
  4. Moen posi-temp shower valve
    By Basement_Lurker in forum Shower & bathtub Forum & Blog
    Last Post: 07-12-2007, 02:06 PM
  5. leaky moen posi temp shower valve fittings
    By billonion in forum Shower & bathtub Forum & Blog
    Last Post: 02-16-2007, 09:02 AM
