Results 1 to 7 of 7
Thread: Access to tub faucet - size of hole in drywall?
    DIY Senior Member AcidWater's Avatar
    Oct 2008
    Default Access to tub faucet - size of hole in drywall?
    How big a hole do I need to cut behind the tub faucet to replace it? Want plenty of working room.
    The valves are 24" above the floor, the spout about 19". 3 valve type with 8" spacing.
    the big question is: How much above & below that should I allow to get to the unions, if present? I want to cut a single piece of drywall out so I can replace it easily.
    Its in a closet so I can go large... stud indicator says there's a stud in the middle.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Go stud to stud on the two outside studs that always does it for me
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Getting to the unions is not the problem because they are right below the hot and cold stems. Piping to the new valve is where you may have problems. If you go below the tub spout, 6" above the hot and cold handles, and stud to stud, you should be fine.
    Oct 2008
    Okey Dokey. Hopefully the replacement will fit the existing unions.
    Aug 2009
    South*East
    Quote Originally Posted by AcidWater View Post
    That's not going to happen. Most new three valves, if you can find one no longer have unions. Even if they did they wouldn't fit the old ones.
    John
    They MIGHT fit if the new faucet is the same make as the old one, but even then they sometimes change the patterns to make them "lighter", (i.e., cheaper).
    Oct 2008
    How do union joints differ? Are they brand proprietary?
    Gotta cut the hole in the wall today...
  1. How Do I Fix This Drywall Hole?
    By Briandl in forum Remodel Forum & Blog
    Last Post: 12-19-2010, 07:13 PM
  2. size hole for single hole faucet
    By bobbieK in forum Plumbing Forum Discussion & Blog
    Last Post: 04-14-2009, 01:31 PM
  3. Access hole?
    By willl in forum Plumbing Forum Discussion & Blog
    Last Post: 07-08-2008, 04:05 PM
  4. Trimming a hole in drywall
    By Mikey in forum Remodel Forum & Blog
    Last Post: 04-04-2008, 06:03 PM
  5. size & location of tub access panel
    By mf915 in forum Shower & bathtub Forum & Blog
    Last Post: 01-03-2007, 01:40 PM
