Results 1 to 7 of 7
Thread: Good quality 3 valve faucet (tub) thats easy to repair?
    DIY Senior Member AcidWater's Avatar
    Oct 2008
    Default Good quality 3 valve faucet (tub) thats easy to repair?
    Need to replace an Eljer. Standard 8" spacing. Want a brand that has a bibb seat which can be removed without hassle, and that I can get parts for easily. I'm told the Eljer might have been installed without being sweated in place; so I might have an easy time installing the new one. Have to cut open the wall to find out...
    There are very few of those left since they don't meet current code (which requires anti-scald technology). Depending on your local inspector, replacement often would require bringing things up to code, and this isn't. While there are some anti-scald add-ons that could be plumbed into it, it becomes a bit more complex, and it's cheaper to just use something that does meet code out of the box.
    Plumber jimbo's Avatar
    Best one...of the very few still made....is Price Pfister. ( Actually known today as Pfister Faucets). It is still available as compression function ( with bibb washer and seats) but a better choice is the ceramic stem version. They use the same trim. Your choice of trims will be limited...dont look for venetian bronze! but parts will be available for your lifetime!
    I can't say for sure that the union on your eljer will match up. Most likely you will have one union piece soldered to the pipe ( unless your plumbing is galv.) so you can unsweat that and replace with the new one if needed.
    Oct 2008
    Default Access to tub faucet - size of hole in drywall?
    How big a hole do I need to cut behind the tub faucet to replace it? Want plenty of working room. The valves are 24" above the floor, the spout about 19". 3 valve type with 8" spacing. Its in a closet so I can go large... stud indicator says there's a stud in the middle...
    Oct 2008
    Something funky with the editor -- the big question is
    How much above & below that should I allow to get to the unions, if present?
    Oct 2008
    I don't see any 3 valve tub sets by Pfister:
    http://www.pfisterfaucets.com/Bath/C...ltisTrade=true
    EDIT: well actually there are, except that their search function has "3 valve" greyed out so you have to page thru everything.
    Pfister 01-111,
    01-311,
    01-321
    and several others up to 01--912 depending on the features and handles you want.
  1. Elger 2 valve tub and shower faucet repair
    By Hackney plumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2012, 12:53 PM
  2. Good quality 3 handle tub/shower valve
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2011, 12:58 PM
  3. Looking for a good quality tub that's less than $400...
    By Travers19 in forum Shower & bathtub Forum & Blog
    Last Post: 01-27-2011, 05:24 AM
  4. Need a good quality sink.
    By ingeborgdot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-17-2010, 06:36 AM
  5. Good quality shower valve
    By Leemonster in forum Shower & bathtub Forum & Blog
    Last Post: 04-25-2006, 09:38 AM
