Results 1 to 2 of 2
Thread: Uphonor motorized zone controller life
    Default Uphonor motorized zone controller life
    I have a small system with four A3020522 Uphonor zone valves. Out of curiosity, if you have any experience with the things, how long do they last? The first set all ended up cracking their housings after a few years and were replaced. Over the years, I've replaced a couple more for various reasons, and just found one whose end switch is intermittent so I've ordered some new ones which should give me a few spares to have on hand. I expected them to need replacement on occasion, but they only seem to last 3-4 years or maybe a little longer.
    What has been your experience?
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    We are an Uponor/Wirsbo "partner" service/installation company here in Minneapolis. The old unit can be a bother. We replace the zone valves if we must, but would rather convert them to the much more reliable thermal actuators. When replacing a the old Wirsbo zone valves we usually start with the valve, adapter ring and top off with the new actuator. This is especially true if they have leaked in the past. We also check for water quality as this can have a long lasting negative effect on many of the radiant floor heating system components.
  1. Motorized Damper/Thermostat question
    By a012210 in forum HVAC Heating & Cooling
    Last Post: 12-07-2009, 06:51 AM
  2. Dual zone vs. Single zone?
    By zombieman in forum HVAC Heating & Cooling
    Last Post: 03-04-2009, 04:48 PM
  3. Motorized Valve Failure?
    By Brian1 in forum HVAC Heating & Cooling
    Last Post: 02-17-2009, 08:07 AM
  4. lineset installed below concrete & motorized dampers
    By mrang@neo.rr.com in forum HVAC Heating & Cooling
    Last Post: 03-30-2008, 02:07 PM
  5. Honeywell motorized valves
    By r247yan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2007, 06:20 AM
