Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Third party 3" flush valves
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    Default Third party 3" flush valves
    I was looking into 3" flush valve other OEMs.
    There is a Fluid Master 540AKR but I wondered about the Korky line. I found nothing other than a 3" flapper so I emailed CS. They said that they have a 5030 carried by True Value Hardware and gave me a SKU number. No product or SKU at True Value Hardware's site and in fact there no 5030 at the the Korky site either.
    Could hardly find it by Googling which is actually a 5030BP.
    Why is it so hard to find? Are 3" flush valves so new to the industry that nobody stocks them yet?
    What toilet is this for? Most of the Toto line uses a 3" flush valve (made for them by Korky), and other toilet manufacturers use them as well. It shouldn't be too hard to find a replacement, but to work right, it should be designed for the specific toilet.
    Apr 2012
    New York, NY
    I don't know why it's not widely-distributed yet. There are a number of sites online that carry the 5030. There was another 3rd party 3" flush valve, but it seemed to have a 3" base and a 2" mouth, making it essentially-useless in my view. I guess that while people are currently needing to replace 3" flappers, they aren't to the point that they really need to replace the whole valve. Just a guess. I emailed Korky CS about why they don't even list the product on their web site. We'll see what they say.
    Good find.
    Apr 2012
    New York, NY
    Jim, Korky makes a lot of "universal" 2" flush valves, and even the Toto probably could take such a valve if someone made one; after all, it's just filling a hole in the china. True that a dual-flush and now for example the 1G use some funky looking flush valves (not to mention the Champion), but the Toto generally uses a basic flush valve like any other, albeit a 3" one. Put in the right flapper, and voila! I have used the Korky universal 2" flush valve on a number of toilets and it works like a champ. I like the wider overflow riser and the fact that you just twist to lock and unlock the adjustable height of the overflow riser, with no cutting required.
    Oct 2012
    Warren, MI
    Well, in another thread, I have a newly installed AS Cadet 3 with a tank leak from the flush valve. Suggestions have slowed the leak but it still leaks. Home Depot is sending another tank.
    I don't really know where this is going to lead to so I was just looking into other flush valves.
    I looked at a Fluid Master at HD and its seal isn't just flat but has two ribs on its sealing surface.
    Oct 2012
    Warren, MI
    Quote Originally Posted by wjcandee View Post
    I've read where one had it leak at the adjustment point on the overflow pipe.
    I think my old toilet was leaking at the adjustment point on the fill valve pipe.
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    Both Korky and Fluidmaster make adjustable replacement 3 inch flappers with instructions on where to set the adjustment for particular brands and models.
Size:  6.5 KBName:  korkyflapper3060bp.jpg
    Oct 2012
    Warren, MI
    Quote Originally Posted by SamC View Post
    I don't have flush problem, it works great in that respect. I have a flush valve seal at the tank leak.
    I think that my second tank is being shipped from Mexico! HD actually suggest removing and returning the whole toilet as that would be faster than just ordering a replacement tank. I told them that was out of the question.
    Luckily my leak is small and some rolled up paper toweling turned end for end once or so a day works. It appears to be slowing down even more unless I'm mistaken.
    Bill
    Just a DIY'r
    Oct 2012
    Warren, MI
    Good find.
    It appears that either/both of us contacting them caused them to update their site to include the 5030BP now.
    Interesting! Their 5030BP instructions state to measure the flush valve hole in then tank and if it's over a certain size, you add a "O" ring to fill the gap.
    Bill
    Just a DIY'r
    Oct 2012
    Warren, MI
    I just read a comment by someone who purchased a 540AKR. They stated that throat on the OEM AS Cadet 3 was 3.25" but the 540AKR was only 2.8"! I wonder what the throat size of the 5030BP is?
    Bill
    Just a DIY'r
    Apr 2012
    New York, NY
    I got a nice email from Korky about that valve. They are trying to get more sources to carry it; I guess it takes time. I looked at the instructions as well, and it reminded me how hard a manufacturer has to work to try to make a "universal" product. Turns out that some manufacturers make bigger holes in the china for their 3" flush valves than do others. I also note that the thing won't work on the Kohlers with the slightly-bigger-than-3" flush valve, which I guess was designed so you have to buy an OEM flapper, or at least forces Korky to make a flapper just for that product, which they do.
    Oct 2012
    Warren, MI
    It wasn't a URL to the site, I just mention that I could only find the 5030BP online at two places, one being a plumbing supply and the other well site that we all know.
    Funny that they believe that it's carried at True Value Hardware, having the SKU# and all but the truth is that it's not listed there.
    Any comment about the true throat sizes of so-called 3" flush valves.
    BTW: The replacement tank I thought I was waiting on from HD, isn't! After waiting a week, I double checked since they've messed up so much before. They have some kind-of 50% rule on a order. I'd have to return the whole toilet. They offered some kind-of 10% discount. I got sooooo mad I hung up on them. I cooled down a bit and called back, wanting to talk to a manager, etc. Got a different person and spent some time with them. The first person didn't explain what they meant about the 10% discount on a second toilet. I purchase a second toilet, swap the tank and return that order. The second person offered a 20% discount. I return the toilet using the original order number and pocket the extra 20%. Depending if I return it or have UPS pick it up determines how fast I get the money back. Still some very dumb rules if you ask me.
    Bill
    Just a DIY'r
    Oct 2012
    Warren, MI
    What about so-called 3" flush valves where the throat is less than that when the stock one is over 3"?
    Bill
    Just a DIY'r
    Oct 2012
    Warren, MI
    No comments about apparent differences in so-called 3" flush valve. This is supposed to be a future standard in the industry, IIRC.
    I haven't looked inside my AS Cadet 3 tank for sometime but I just discovered that it's marked as a Fluidmaster 540 somewhat similiar to the 540AKR. One difference is the seal, the OEM is flat whereas the AKR has rib(s) on the sealing surface. I wonder if it has a undersized 3" throat also?
    What's used in the Toto? What's used as a Toto replacement if needed, Korky or Fluidmaster?
    Bill
    Just a DIY'r
    Toto (at least in the USA) uses rebranded Korky stuff for the most part. You can buy the same thing at Lowes and many other sources, but it will say Korky for Toto rather than being labeled Toto.
  1. Why I like Mansfield Flush Valves.
    By boyntonstu in forum Toilet Forum discussions
    Last Post: 08-04-2011, 01:31 PM
  2. Question about sticky "Submersible Pumps and multiple check valves?"
    By Gabe1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-27-2011, 02:56 PM
  3. Replies: 3
    Last Post: 08-09-2010, 06:44 PM
  4. I hate shower diverter "valves"
    By Fubar411 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-24-2010, 06:43 PM
  5. Replies: 4
    Last Post: 03-09-2010, 07:52 AM
