Results 1 to 3 of 3
Thread: Toilet vent
    DIY Junior Member KShirriff's Avatar
    Nov 2012
    Tuscaloosa, Al.
    Default Toilet vent
    I have a toilet in the corner of the house, the vent is in the exterior wall and runs up to the attic area. Is it possible to attatch the vent after the combination why/tee turns horizontal? This would be at the top of the 3" horizontal pipe and vent up into the exterior wall. Or should I try to lower the height of the the horizontal pipe and try to vent it out the side of the vertical just below the toilet flange?
    The vent can be within six feet of the floor flange on a toilet.
    Either at the same level as the trap arm, or lower with a wye fitting on the vertical.
    Since a toilet bowl is refilled after the flush, and the bowl is the trap, it's treated a little differently from the rest of the plumbing fixtures.
    Nov 2012
    Tuscaloosa, Al.
    Thanks Terry.
  1. Connecting New PVC Pipe Vent to Existing Cast Iron Vent Pipe in a Wall for Toilet
    By DanMcD in forum Plumbing Forum Discussion & Blog
    Last Post: 10-16-2012, 10:40 AM
  2. Can you tie lav drain into a toilet vent (wet vent)? W/SKETCH
    By kmuddzy in forum Plumbing Forum Discussion & Blog
    Last Post: 01-27-2012, 10:15 AM
  3. Replies: 8
    Last Post: 06-13-2011, 10:38 AM
  4. Can I install toilet vent in vertical section of pipe below toilet?
    By dayster in forum Plumbing Forum Discussion & Blog
    Last Post: 06-28-2008, 10:36 AM
  5. Inspector says: “The toilet-vent must be upstream of the toilet.”
    By lahabra in forum Plumbing Forum Discussion & Blog
    Last Post: 02-13-2008, 04:26 AM
