Results 1 to 4 of 4
Thread: water softener line clogged
    DIY Junior Member rmsco1956's Avatar
    Nov 2012
    Florida
    Default water softener line clogged
    I was wondering what happens if the drain line is clogged? Will the brine tank fill up with water? If someone has any answers it would be very helpful.
    Jan 2012
    California
    The system will not work. Once you have repaired the drain line, regenerate with a little extra water in the brine tank and all should be well again if no other problems exist.
    This is a very basic answer, if you want more details, let us know and we will provide more information.
    The answer to the question is yes it will.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Water must flow to the drain in order to cause a suction. If the drain line is clogged, water will fill the brine tank.
  1. Water softener discharge line
    By uuu1234 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-21-2012, 04:11 PM
  2. Constant Water flow through water softener drain line
    By Dale M. in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2011, 02:13 PM
  3. Replies: 2
    Last Post: 04-09-2011, 05:21 PM
  4. Water softener discharge line
    By uuu1234 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-04-2009, 05:01 PM
  5. Connect a new line to a water softener
    By marky in forum Plumbing Forum Discussion & Blog
    Last Post: 11-28-2008, 02:07 PM
