Are the walls around the tub cbu or drywall? Drywall should never be used in a wet area. Is that drywall mud or mortar? If mortar, your tub will likely be scratched cleaning off the excess. It should NOT be tight there, but there SHOULD be a vapor barrier installed behind it, lapped over the tiling flange. You might be able to use a topical waterproofing material, one is RedGard from Custom Building Products, or Hydroban.
If that's drywall mud, you've got a problem...well, even if it's thinset, you have a problem. Wait for one of the pros, but it sure looks pretty sloppy and not in accordance with general practice or manufacturer's instructions to me!
His help didn't shim the cement board so the edges don't match the drywall. I brought this up and he didn't think it was a big deal, his mud guy would just float the joint out. I understand this can happen on remodels but the height difference was 1/8"+ and there is only ~7" to float the joint before the edge of the surround. It looks like S@!t.
