Results 1 to 5 of 5
Thread: Connecting to outside sewer line
    DIY Junior Member hoopers2's Avatar
    Nov 2012
    Texas
    Default Connecting to outside sewer line
    Hello,
    I am adding a 2nd story powder room with a toilet and sink to my existing town-home.
    I am draining the two fixtures with a 3 inch line. The drain line runs down an exterior wall (on the inside of it), and then exits just above ground level. From that point, it is about a 7 foot run to my outside, 3 inch cleanout.
    Not sure how the cleanout line is tied into the horizontal exit line below.
    Can I "T" into this vertical cleanout line?
    Or must I dig down to the horizontal line that the "vertical cleanout line" connects into? If I have to T into the lower horizontal line, what is the best way to do this? One of those rubber connecting T's or something better?
    Thank you.
    DIY Junior Member hhplumbing's Avatar
    Oct 2012
    Victoria, BC
    hello,
    yes you can tie into the verticle line, but you will have to use 45 degree fittings insted of 90 degrees elbows. and try and get it in the ground as soon as you exit the building
    hope this helps
    HouseHold Plumbing Forum - Reviews and how to solve your plumbing problems . Our Journeymen Plumbers will help you out anyway we can before hiring a costly plumber when its not needed.
    Visit http://www.householdplumbing.com sign up today and get your problems solved.
    A horizontal waste line can enter a vertical with a Santee fitting.
    If you were dropping down to the horizontal line, that would require a wye fitting.
    Nov 2012
    Texas
    HEre, you CANNOT connect a drain to a cleanout riser. But the type of cleanout fitting in the ground would determine whether it would be a good idea for you to do it even if it were permitted. IF it is a "two way" cleanout fitting" then you CANNOT connect to it. If it is a "Y" or combo then it will work.
  1. Replies: 2
    Last Post: 06-27-2012, 07:15 AM
  2. When connecting 4" ABS sewer line to Cast Iron, how deep is deep enough?
    By Man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2012, 08:16 PM
  3. Connecting 3.5" IPS to ABS for sewer line extension
    By MrsTiki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2012, 07:18 PM
  4. Connecting Hot Water Heater Drain Pan to Sewer - Will Swing Check stop sewer gas?
    By Jim109 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2011, 12:43 PM
  5. Sewer line to city line (sewer lateral) question r/o
    By H20Melon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2005, 05:12 AM
