Cutting cast iron can be a pain. The way it was done may no longer meet current codes, so a direct replacement may not be the best choice. But, yes, you can replace it with abs or pvc. Use a no-hub connector above ground - this is thin rubber sleeve with a metal reinforcement band around it, and screw clamps to tighten it down.
