Thread: 9 feet down and lots of water
    DIY Junior Member TMx57's Avatar
    Nov 2012
    Bothwell, Ontario
    Default 9 feet down and lots of water
    Hi,
    I have a farm in South Western Ontario, moved from the city 2 years ago. I have a shallow sand point well with a Duro pump (piston pump) I had very little water available but the previous owners said the water was never a problem. Not being satisfied by having to wait 3 hours to take a shower after doing 2 loads of laundry I installed a huge diaphragm tank ($500) just after a steel tank. Not much improvement! Put in a $750 new pump. Same thing. I have a spare pump now! Finally decided to dig up the old point. Not as hard as I thought. Old point was down 12' to the bottom. I put a new 3' point down 9' + 3' point. I am getting 3to 4 gal/min. So what's my problem?
    Should I worry that I am to close to the surface? ie. field run off, inconsistent water.
    The land is all sand and no live stock for miles.
    P.S. New Sand Point and materials $200 and a days work
    Moderator valveman's Avatar
    Mar 2006
    The pump sees a larger tank as another load to satisfy, so you actually get less water in the house. You didn't give the size of the pump so we don't know if the 3-4 GPM is because of the pump or the well. Either way 3 GPM is 4300 gallons per day, which is enough for 10 houses. You just need to put this in a storage tank so with an additional pump you can produce as much as you need for short periods of time when water is actually being used in or around the house.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by TMx57 View Post
    You haven't really told us what your problem is. The title says "lots of water" or are you being facetious?
    Is the pump sucking air? A 3 foot sandpoint set only 9 feet down is not ideal. If the pump sucks air, then you are up against the cone of depression and need to go deeper. If it's not the cone of depression and not sucking air you need to put down a longer sandpoint or multiple sandpoints in parallel to get more GPM.
  1. Sump pit always has lots of water - next step ?
    By Jake_59 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2009, 02:55 PM
  2. Air in Water Line (Lots of it!)
    By JPSnaab in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-05-2008, 05:40 AM
  3. Replies: 5
    Last Post: 01-04-2008, 08:17 AM
  4. Lots of Water Around HVAC Outside Unit
    By here4more in forum HVAC Heating & Cooling
    Last Post: 08-10-2007, 12:48 PM
  5. lots of water in vent pipe
    By Lea in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-06-2005, 11:44 AM
