Results 1 to 5 of 5
Thread: Seal Well Entry
    DIY Junior Member troutster's Avatar
    Nov 2012
    Georgia
    Default Seal Well Entry
    Hi,
    After hurricane sandy I noticed that where the well pipe enters my basement there was a small puddle. I noticed a drip that appeared to be coming from where the well pipe (PVC) entered the basement through the foundation.
    Today I went for a closer look. The concrete around the well pipe is in fact nice and tight with no cracks or openings. I did, with this closer look, see that there is a second, smaller pipe (maybe 1/2 inch) that comes through just above the water pipe. This pipe has the wires running out to the submersible pump.
    The end I can see appears to have nothing blocking it. I assume that the other end is sealed (maybe not fully, etc) since it is only a small drip. Is there something that I can put into this little tube w/ just the wires running through it to seal up the opening?
    Scott
    Moderator valveman's Avatar
    Mar 2006
    Silicon works for that. But you need to find out where the water is coming from. Sometimes the water coming in the electric conduit is leaking from the pipe to the well somewhere.
    Jan 2008
    For sealing conduits, I use Gardner Bender duct seal putty. It or a variation of it can be found in most electrical supply departments.
    Nov 2012
    Georgia
    Here are a few pics. Still think just shooting some silicon in there will seal it up?
    one
    two
    three
    Nov 2012
    Georgia
    Have you ever seen this? Maybe a different brand, not sure where I could even get this, unless I am missing something.
    http://www.polywater.com/ductseal.html
    Anything like that I could get local? Or at a big box?
  1. Back entry door install
    By Master Brian in forum Remodel Forum & Blog
    Last Post: 11-20-2009, 01:46 PM
  2. weatherstripping an uneven entry door
    By r_2016 in forum Remodel Forum & Blog
    Last Post: 08-30-2007, 01:17 AM
  3. HVAC Rapid Entry
    By Jed54 in forum HVAC Heating & Cooling
    Last Post: 08-28-2007, 06:29 PM
  4. Marble entry way
    By Cookie in forum Remodel Forum & Blog
    Last Post: 08-14-2006, 11:46 AM
  5. How to refinish a wood entry door?
    By chassis in forum Remodel Forum & Blog
    Last Post: 07-28-2006, 12:13 PM
