Results 1 to 10 of 10
Thread: flooring
    Default flooring
    I am thinking about replacing the kitchen flooring. Can I lay tile or vinyl over lineoulm? If so, what preparations would be necessary before the actual laying? Thank you.
    Usually, they lay 1/4" luan, then fill all of the joints and nail holes so it is a nice smooth, clean, unwaxed surface to attach the vinal to. Then, make a template, cut the stuff and glue it down. Depending on the type, it may only get glued at the edges and seams.
    Luan chips a lot if you don't use a sharp blade, preferably one with fine teeth, course that makes it a little longer to make the cut. Also, it is harder to make a straight cut with a handsaw. The idea of putting this stuff down prior to the new vinal is to make sure you get a nice clean and flat surface. Any imperfections need to be filled in or patched, or they will show through the relatively soft vinal. Fine furniture has been made for centuries with hand tools...laying luan for a new vinal floor isn't fine furniture.
    Default luan
    The floor covering men that I associated with always used a spackling to fill seams on luan.
    Plumber Cass's Avatar
    Nov 2005
    In the past I have cut luan with a sharp utility knife, 3-4 passes up against a straight edge with good downward pressure and thats it. Slices right through like butter. I repeat sharp blade.
    DIY Senior Member Cal's Avatar
    May 2005
    Northern Virginia
    Cookie, You said "Tile or vinyl" DO NOT USE LUAN if you are going to lay ceramic tile. The mortars and glues for ceramic will not make a good bond with the luan.
    Yakima WA
    You can lay vinyl tile over embossed vinyl. You have to use a leveling material to fill in the embossing and make the surface smooth. This leveling material is sold where ever vinyl tile is sold. I've never done it, but it appears to be a fairly straight forward job. The main drawback I see is that the floor will be about 1/8" higher than it was so adjoining floors won't match. Could require some close fitting doors to be trimmed, but that isn't very difficult to do.
    Sound and Light Suppervisor for a School District tjbaudio's Avatar
    Dec 2005
    Wisconsin
    Exclamation
    Quote Originally Posted by Cal
    My understanding is Luan is not approved for underpayment of any kind and will void your flooring warranty. While it is great stuff to work with I would not use it under a floor. Use plywood rated for under layment if you must cover your old flooring. It may not be needed though. It depends on what kind of shape your floor is in now and what the new product says it will stick to.
    DIY Junior Member Tygon's Avatar
    Jan 2006
    Alaska
    I had never heard about luan not being okay for vinyl underlayment.
    But DO NOT use luan if you are thinking of EVER doing a ceramic floor. I can attest that ceramic tile will not stick to it. Even going over it with cement board, the thinset between will not stick and serves only as a filler at best.
    Depends on the product as to lauan.
    We had planed a kitchen floor around one vinyl product, and installed plywood. We then changed our mind to another manufacturer's product. Had to either cover the plywood or pull it up and replace it with lauan. Ended up pulling the plywood and laying lauan.
    Paul
